Still overheating
I really like this one I got from "the parts bin" as many aftermarket thermostats have a much smaller opening.
This aftermarket thermostat is closest to factory that I have seen.
http://www.thepartsbin.com/
It is a NTK thermostat and they are available in 3 temperatures.
The wahler thermostat also features a larger diameter passage.
Edited by HowlerMonkey
  • 3 weeks later...
At idle on a cold day in SoCal I can not get the engine to 160F when idling. It will sit between 140-152^F measured at the CHT at the back of the head, and about 10^F lower at the thermostat.
I have to drive it to get enough load on the engine to satisfy the 160F - 170F lower thermostatic control range.
All stock cooling system, with clutch fan, and shroud in a 260Z.
On a hot day, this is not an issue.
If you are running appreciably hotter than 185, the chances for boiling in the back of the engine (head) are greater. Run a 16# radiator cap at least, and don't loop the heater hose if you're bypassing the core! If you're 220^F out the thermostat housing, you're over 230^F at the back of the head---way too hot.
Edited by Tony D
When I got the car the heater hose had already been looped, so this could be the problem? If the previous owner looped it couldnt that imply that the heater core was leaking?
Are they hard to remove and repair/replace?
