240zstroked Posted October 2, 2011 Share Posted October 2, 2011 (edited) ok I want to know what rear gears do I have, I would like to run a r230 rear end with a v8.I pick up the rear end not knowing the difference. Edited October 6, 2011 by 240zstroked Quote Link to comment Share on other sites More sharing options...
RB26powered74zcar Posted October 2, 2011 Share Posted October 2, 2011 Nothing shown. Quote Link to comment Share on other sites More sharing options...
231Z Posted October 2, 2011 Share Posted October 2, 2011 Between what R230's? The 300zxtt came with one and so did the Nissan Armada. The differences are subtle. Do a search on my R230 conversion and you'll see photos. Tyson Quote Link to comment Share on other sites More sharing options...
johnc Posted October 3, 2011 Share Posted October 3, 2011 Pick it up. That will show you the difference. Quote Link to comment Share on other sites More sharing options...
240zstroked Posted October 3, 2011 Author Share Posted October 3, 2011 untitled.bmpFetching info... This is my r230.I dont know what it came out of.The 300zxtt or the Armada. Quote Link to comment Share on other sites More sharing options...
mrcheeze36 Posted October 4, 2011 Share Posted October 4, 2011 From the diff flange and input yokes, its not a 300ZXTT R230 diff. Quote Link to comment Share on other sites More sharing options...
240zstroked Posted October 6, 2011 Author Share Posted October 6, 2011 On 10/2/2011 at 2:05 AM, 240zstroked said: How can you tell the differences between r230 So how can you tell what gears you have. Quote Link to comment Share on other sites More sharing options...
beermanpete Posted October 6, 2011 Share Posted October 6, 2011 On 10/6/2011 at 1:18 AM, 240zstroked said: So how can you tell what gears you have. 2 ways to tell the gear ratio: 1) Turn the input (pinion) shaft, counting the turns, until the output shaft turns 1 full turn. 2) Take the cover off and count the teeth on the gears. Quote Link to comment Share on other sites More sharing options...
johnc Posted October 6, 2011 Share Posted October 6, 2011 3. Read the ratio stamp on the ring gear. Quote Link to comment Share on other sites More sharing options...
240zstroked Posted October 7, 2011 Author Share Posted October 7, 2011 On 10/6/2011 at 3:04 PM, johnc said: 3. Read the ratio stamp on the ring gear. Ok.thank you all for the info.The info stamped is 46:13 which come out to be 3.53.Now I'm back to the original thing what didi it come out of? Quote Link to comment Share on other sites More sharing options...
NewZed Posted October 7, 2011 Share Posted October 7, 2011 I think that's the common ratio (actually 3.538 or 3.54) for automatic or turbo 84-88 300Zxs also, with short nose R200s. And your picture looks like this one on the MM site - http://www.modern-motorsports.com/catalog/mm_gallery.php?album=2008+March+Proto+Q45+R200+Mounting+Proven+Brian+G%2F&pic=DSCN1974.JPG - of a short nose R200. I think that the R230 is much bigger. Quote Link to comment Share on other sites More sharing options...
mrcheeze36 Posted October 9, 2011 Share Posted October 9, 2011 On 10/7/2011 at 11:05 PM, NewZed said: I think that's the common ratio (actually 3.538 or 3.54) for automatic or turbo 84-88 300Zxs also, with short nose R200s. The 84'-88' 300zx came with long nose r200 diffs. The Infiniti Q45 in the US came with a short nose R200 with a 3.54 ratio. I measured the Q45 short nose R200 and 300zxtt short nose R230, but I need to look for the info. The R230 is bigger and heavier. Quote Link to comment Share on other sites More sharing options...
NewZed Posted October 9, 2011 Share Posted October 9, 2011 I'm not doing well on matching cars with diffs... Regardless, it looks like the short nose R200 on the MM site. Why does 240zstroked think it's an R230 is the question. Quote Link to comment Share on other sites More sharing options...
mrcheeze36 Posted October 9, 2011 Share Posted October 9, 2011 On 10/9/2011 at 6:14 PM, NewZed said: I'm not doing well on matching cars with diffs... Regardless, it looks like the short nose R200 on the MM site. Why does 240zstroked think it's an R230 is the question. Many were calling the Q45 R200 an R230 awhile back so it's understandable...you can see this in a lot of the old threads. Quote Link to comment Share on other sites More sharing options...
