13 inch wheels
If you look at pictures of Paul Ruschman's yellow autox car on 13's and compare to any Z that has 17's or 18's on it, you can see that Paul's car is lower to the ground, and the rear control arms are actually still pointing down from the center to the wheel, so the geometry isn't all F'ed up and he still has plenty of travel. At some point you do have to consider the possibility of smacking the chassis on the ground before the suspension bottoms, and some real low autoxers have skid plates for that reason. Terry Oxandale actually modded the struts to get his roll center back above ground in the rear of his extremely low Z with 17s, he's the only one that I've seen that has done it.
Edited by JMortensen
