Rota RB-R 17x8.5 +4 offset. What size tires?
Just got a set of Rota RB-R 17x8.5 +4 offset just wanted to know what size tires to go with?
I got a 73 240Z with coilovers 5way adjustable with eibach springs. And bought fender flares. I got 16s 225/50/16 all around on the car right now. Was thinking of going 245 or 255.??
Any ideas or pics? Thanks
Edited by 1siCk240Z
Running 245/45/17's all the way around and the tires do rub on the rear. The tires catch the inner fender just above the fender opening. The fender rubs the tire sidewalls over bigger bumps or hard turns. 235 might clear with no problem.
I'm currently running these in the rear of my car.
225/50/16 16x8 +10 w/ 10mm spacer in the front.
245/40/17 17x8.5 +4 w/ 10mm spacer in the rear.
It is currently at stock ride height but the tires do fit within the fender line.
  On 12/7/2011 at 1:37 AM, ComicArtist said:
^ beautiful chassis. Love the color.
But you should lower it some.
Thanks! I will be, I have a lot in store for it actually, and coilovers are next on the list, unless something else breaks on it..then that comes first
  On 12/3/2011 at 10:50 PM, pat1 said:
Pat1,
I believe your car has the best Stance/ wheel combo.
Do you have lowering springs with stock suspension components? or are you using coil overs? I recently acquired a set of rotas 17X8.5 +4 offset and have a early 74' 260Z with Stock suspension. I assume I will need to roll the fenders, will I also need to use spaces to clear the stock spring perches? Any help is greatly appreciated.
Thanks
