disepyon Posted December 9, 2011 Share Posted December 9, 2011 The engine is the stock L24 with su carbs. ITs been about a week or so since i drove it back when it was warmer out. Now that its cold and winter is here the engine wont start up. It just turns. IT wont attempt at all to try and fire up, just keeps turning over and over. Any help please? im fairly new with this motor and carbs. Thanks, Brent Quote Link to comment Share on other sites More sharing options...
NewZed Posted December 9, 2011 Share Posted December 9, 2011 Spray some starter fluid in the carb throats, then crank it over. If it starts, you have a fuel problem, if not you might have a spark problem. Quote Link to comment Share on other sites More sharing options...
disepyon Posted December 10, 2011 Author Share Posted December 10, 2011 Well i just found out that the fuel lines going to the carbs are bone dry, even when i turn the key on in the ignition position no fuel and when i try and crank no fuel. could this be a fuel pump failure? Spark plugs are terrible condition but should still spark. Quote Link to comment Share on other sites More sharing options...
NewZed Posted December 10, 2011 Share Posted December 10, 2011 Could be anything between the dry portion of the fuel line and the liquid in the tank. Is the gas gauge on E? Quote Link to comment Share on other sites More sharing options...
disepyon Posted December 10, 2011 Author Share Posted December 10, 2011 On 12/10/2011 at 8:04 PM, NewZed said: Could be anything between the dry portion of the fuel line and the liquid in the tank. Is the gas gauge on E? NO, has about half a tank. Quote Link to comment Share on other sites More sharing options...
disepyon Posted December 10, 2011 Author Share Posted December 10, 2011 (edited) This may be a dumb question, but does my 1972 240z have a electrical fuel pump or just the mechanical one on the engine and thats it? Cause im reading the clymer manual and it says the 240z does not use the carbon canister or electric fuel pump. the mechanical pump had been replaced when i bought the car in mid october. Ive looked everywhere underneath my car and dont see the electrical fuel pump like the 260z has. Edited December 10, 2011 by disepyon Quote Link to comment Share on other sites More sharing options...
disepyon Posted December 10, 2011 Author Share Posted December 10, 2011 FOUND the problem!!! it was a clogged up fuel filter. After spraying the hell out of it with the air hose, fuel actually pass through it now. I must have a dirty azz fuel tank. took awhile to prime the fuel but everything works now. debating wether or not to replace it.... I already have a ls1 motor im swapping in it, but wont be until spring time. Quote Link to comment Share on other sites More sharing options...
