tjandriesen Posted December 19, 2011 Share Posted December 19, 2011 What are people running for rear brakes on Z cars racing in E Production? Quote Link to comment Share on other sites More sharing options...
JMortensen Posted December 20, 2011 Share Posted December 20, 2011 (edited) I believe they run stock brakes or early 280ZX. Greg Ira would know for sure, he's the most successful EP Z racer in the country. I've seen him here but I think he frequents www.classiczcars.com more, so you might sign up there if you're not already a member and PM him. EDIT--screen name "gira" Edited December 20, 2011 by JMortensen Quote Link to comment Share on other sites More sharing options...
tjandriesen Posted December 20, 2011 Author Share Posted December 20, 2011 (edited) I believe they run stock brakes or early 280ZX. Greg Ira would know for sure, he's the most successful EP Z racer in the country. I've seen him here but I think he frequents www.classiczcars.com more, so you might sign up there if you're not already a member and PM him. EDIT--screen name "gira" Thanks! Edited December 20, 2011 by tjandriesen Quote Link to comment Share on other sites More sharing options...
johnc Posted December 20, 2011 Share Posted December 20, 2011 From the GCR: b. Cars fitted with rear drum brakes, can convert to rear discbrakes. When converting from rear drum brakes to rear disc brakes: 1. Rear brake rotors can be no larger in diameter than the largest permitted front brake rotor. Rear brake rotors must be solid and made of a ferrous material. Rear brake rotors can not be cross drilled or slotted. 2. Rear brake rotor hats can be made of a ferrous or aluminum material. 3. Rear calipers and mounting brackets are unrestricted but must be made of a ferrous or aluminum material. The standard and alternate brake listings on a vehicle’s specification line, does not prohibit a car that was fitted with rear drum brakes as stock from converting to rear disc brakes under this rule. 240 VTS(Front) 252mm (9.92) Vented Disc (Rear) 258mm or 269mm Solid Disc - Discs and calipers from 280-ZX. Quote Link to comment Share on other sites More sharing options...
tjandriesen Posted December 20, 2011 Author Share Posted December 20, 2011 From the GCR: Thanks John. I had read the GCR but was looking for the best, legal set up to meet those requirements. Quote Link to comment Share on other sites More sharing options...
RACERZ Posted December 24, 2011 Share Posted December 24, 2011 We have Doug Piners old EP car we have zx lightened rotors with wilwood dynalite singles, we are looking to upgrade to the Sierra rears (you have to turn down the stubs to fit the hats) but they will be about 2 lbs lighter then the lightened zxs. Greg runs the dynalite duals about 1 lb more for the caliper, but pads last longer (larger pads), both will work well we have had no probles with fade and pads are good for 5-6 races I belive Greg runs hawke pads we run the performance friction. You will have to fabricate a mount no one makes one to fit the calipers, but its not a big deal to modify an existing mount to work. Quote Link to comment Share on other sites More sharing options...
