Fuel Injector Flow Rate Question
Dadaluma
I Need some clarification on injector flow rate. I have fuel injectors from a 1975 Mercedees 450sel, JWT sells with their "450 kit" and says that they are 420cc injectors. When I look up these same injectors online they are rated at 379.9cc @ 43.5psi. Is JWT assuming that you have to increase your fuel pressure to around 50psi?. On my setup I am running these injectors @37psi (stock psi) , so would that essentilay make them around 323cc@37psi?
