macambra Posted January 22, 2012 Share Posted January 22, 2012 I am making some final wiring harness pieces for my MS2 install. While I wait for my EV1 connectors to arrive I have some time to kill-so, what are some common settings or wiring errors I need to watch out for? 83 s130 turbo Schnieder stage 2 cam- .460 lift-manual lash adj's .63 T03/04 ArizonaZ 12.5lb flywheel TWD 60mm throttlebody Greddy Type RS BOV Adjustable FPR Stock lower end-rebuilt DIYAutotune 12-1 CAS disk MS2 built per MS2X specs,MS2X latest firmware,Bip373 coil driver,USB-RS232 retrofit-boardmount I have built the MS2 and tested with Jimstim. Manufactured the main harness and my own design relay board in a project box with connectors and fuses (tested SAT on the bench) Quote Link to comment Share on other sites More sharing options...
mobythevan Posted January 23, 2012 Share Posted January 23, 2012 Common noise issues: Shield your crank sensor wires to megasquirt. Install a capacitor on 12 volts at your coil/coils. Use resistor spark plugs. Don't run wiring near the coil/coils or plug wires Noise is the most common problem with megasquirt installs. Quote Link to comment Share on other sites More sharing options...
Tony D Posted January 23, 2012 Share Posted January 23, 2012 And load your software on someone else's laptop and test anything you suspect may be a problem with the MS on it... You never suspect the comm chip going bad in your laptop. Mine did and it was the root of all evil in my startup. Fixed my laptop, and all was right with the world! Quote Link to comment Share on other sites More sharing options...
Tennesseejed Posted January 23, 2012 Share Posted January 23, 2012 Some folks have trouble properly wiring the ignition relay(s) to power MS. Serial comms between MS and the laptop can be finicky. I had good luck the first time around. Other people end up buying several different serial cables before they get comms. Quote Link to comment Share on other sites More sharing options...
