Novacaine Posted February 1, 2012 Share Posted February 1, 2012 I haven't been able to find any information on what I would like to try and do. A buddy if mine has a 240sx with a front 5 lug conversion and want to revert back to 4 lug. So we found another 4 lug shell for sale. So my question is is it possible to use the 240sx 5 lug front spindle on my 77 280z? And I know the rotors are set up different so will the rotors and calipers from the sx work as well? Or would I need to try and graft the entire strut assembly from the sx to my z? Quote Link to comment Share on other sites More sharing options...
kaito Posted February 3, 2012 Share Posted February 3, 2012 NO Quote Link to comment Share on other sites More sharing options...
Novacaine Posted February 3, 2012 Author Share Posted February 3, 2012 No what? That's really not an answer to my question. Maybe my question isn't clear enough. Will the 240sx 5lugwould conversion work on my 280z if I use the brakes and calipers to? Quote Link to comment Share on other sites More sharing options...
seattlejester Posted February 3, 2012 Share Posted February 3, 2012 Pretty sure the sx hub won't fit on the 240, just looking up the bearing will tell you that they run different sizes and most likely widths. So without a trip to the machine shop to bore it to a similar size and shave it down for the correct width not that great of a chance of them going on. Plus the stock front rotor size on a 240sx is almost 3/4 of an inch smaller than that on the Z but it is vented so the caliper won't fit, and even if it did, it wouldn't function correctly. If you grafted the sx spindle and hub into your Z strut, you would be faced with the problem of different tie rods, lca's, sway bar mounts, etc. And grafting the whole sx suspension is a fairly ridiculous task, requiring a literal graft of the entire front end, followed by reinforcement and fair amount of welding, this would also leave you with the problem of having to source an sx engine as the cross member would be different. So the answer would be no, unless you have access to a race shop/machine shop/welder. Quote Link to comment Share on other sites More sharing options...
Novacaine Posted February 3, 2012 Author Share Posted February 3, 2012 Sounds good to me guess ill try a different approach thanks. Quote Link to comment Share on other sites More sharing options...
erehemantresni Posted February 3, 2012 Share Posted February 3, 2012 This picture is a memeber on here. Almost all bolt in I believe. 240sx front strut. 240sx front hub/spindle brakes. Stock LCA and TC rod. The spindles are swapped left to right to allow front front steer. Would be a cheap brake upgrade if someone had more details on this. The q45 brakes with a newer altima 4 lug rotor bolt on the stock SX hub I think.. Quote Link to comment Share on other sites More sharing options...
Forcer Posted February 4, 2012 Share Posted February 4, 2012 SR240Z, Vildinni Motorsports. I asked about that car awhile ago. They said they aren't going to make conversion kits, but would do it if a customer wanted. Quote Link to comment Share on other sites More sharing options...
