replaced air flow sensor, still same problem
so my car began doing all the symptoms of a bad airflow meter, so i took it to a shop for diagnosis. they confirmed my suspicion that it was a bad airflow meter and a clogged egr system. I replaced the air flow meter, and unclogged the EGR system and replaced the EGR valve, however the problem still persists. the car idles poorly and misfires under acceleration. it sounds like its not running on all cylinders. All the injectors were tested to be working, and when i try to adjust the idle using the idle screw it doesn't seem to respond much to it. Also if i take the oil cap off when the car is running it doesn't run any different (i Believe the engine is supposed to die if you do that).
So Hybrid Z community, what are your thoughts on the cause of this problem, i dont want to keep throwing money at parts that arent causing the problem.
Car is a 1977 280z
Edited by Ghettodeffender
It kinda sounds like you have a large vacuum leak or the timing is way off.
For vacuum, check the intake boot for cracks in the accordian section, check all the small lines running around the engine, all the hoses for pcv. Borrow a vacuum tester from O'Reilly's or wherever then follow the instructions on this page: http://www.atlanticz.ca/zclub/techtips/vacuum/index.html
Do a check of the timing. '76 manual shows idle timing of 10* BTDC (engine cold) or 7* (engine warm).
Hope that helps, if not, those are still good things to do and they're free.
No it won't die if you remove the oil cap.
How is your timing? Fuel pressure? Filters? Ect.
We need a little more info than you have given.
Fuel Filter apears to be new, fuel pump is new, fuel pressure set to 36 psi, not sure on the timing, however the car was only sitting in my drve way and i would start it up and let it idle every day, i havent been driving it since the clutch went out. it was idling fine until i removed the valve cover to clean and replace the original gasket, i used a new gasket and sealent on the valve cover and put it back on the engine, i then started her up about an hour later and she starting running like ****, as i described. so i am going to remove the valve cover, put on the gasket this time without sealent and tighten it up nicley to see if that gets rid of the vaccume leak. that is the only thing i can thing it might be (most of the time something like this happens, it seems to be part of a human error). ill let you guys know if that was the source of the vaccume leak
K. Sounds good. Hope you find the problem.
So just an update, i replaced the vlave cover gasket, this time i sanded the **** out of any place that could potentially cause a vaccum leak, so when i put the gasket back on everything was smooth, i then beaded oil on the gasket and put the valve cover back on, fired her up and still runnin like ****, i tested it with a vaccume tester again, and it was at 13 psi at idle like it had been before i changed it. so i took it to a local shop to have them diagnose the vaccume leak source.
