Whats the cost?
JacktheRiffer
  • 1 month later...
Get a 280z as it will already have fuel injection and a compression ratio you can add a low boost turbo system.
If you are good a rounding up good used parts then you can turbo charge a 280 for 300 to 600 dollars and do it over the weekend if you use a FMU for fuel enrichment and lock out the ignition timing curve.
From my experience you should be able to run a 14.5 @ 95 mph in the 1/4 mile without an intercooler with stock 280zx boost (7-8 psi) and around 14.0 at 100mph with an Intercooler.
I ran 13.4 at 101 on 6-7psi with an intercooler and megasquirt, I WILL go mid 12's this year with it.
I would NOT count on doing it for sub-$1500, these engines are old and will have surprises, things will nickle and dime you to death. Plan on at LEAST 50% more than you're planning on.
