Wangan280 Posted March 4, 2012 Share Posted March 4, 2012 (edited) The nightmare is becoming less of a nightmare, We're getting there slowly but surely. So we have spark now, and the car will run if we dump a little fuel down the intake. So now it's a matter of fuel delivery. The fuel pump IS working, but for some reason the injectors aren't firing properly. They are getting constant power, even when the key if off. This shouldn't be possible. I checked the wires on the plug into the ecu. They are getting constant power also. I have no idea what to do. This is a 83 NA to 83 Turbo swap. We have wiring schematics the size of the car LOL (pops' eyesight or lack of...) and we're getting power to the necessary wires (at least we think we are.) the timing is correct and it is sparking. these damn injectors are pissing me off :| Thanks Jordan Edited March 4, 2012 by Wangan280 Quote Link to comment Share on other sites More sharing options...
NewZed Posted March 4, 2012 Share Posted March 4, 2012 There's most likely a good description in the FSM, Engine Fuel section, of how/where the ECCS gets its signal to determine when to ground the injectors. EFI uses the blue wire from the coil (-) to Pin 1 but the ECCS might use the CAS. If you haven't already looked... Quote Link to comment Share on other sites More sharing options...
HowlerMonkey Posted March 5, 2012 Share Posted March 5, 2012 Injectors get constant power with the key on. The ecu delivers the negative signal. I've seen many nissan ecus fuse the injector driver and the zener diode when connecting the battery backwards. Quote Link to comment Share on other sites More sharing options...
Wangan280 Posted March 5, 2012 Author Share Posted March 5, 2012 On 3/5/2012 at 2:40 PM, HowlerMonkey said: Injectors get constant power with the key on. The ecu delivers the negative signal. I've seen many nissan ecus fuse the injector driver and the zener diode when connecting the battery backwards. So the injectors get constant power and pulse when receiving the negative signal? Quote Link to comment Share on other sites More sharing options...
HowlerMonkey Posted March 6, 2012 Share Posted March 6, 2012 Yes They also all fire at the same time. Quote Link to comment Share on other sites More sharing options...
Wangan280 Posted March 6, 2012 Author Share Posted March 6, 2012 On 3/6/2012 at 4:03 AM, HowlerMonkey said: Yes They also all fire at the same time. Then I have no idea whats wrong. :| Quote Link to comment Share on other sites More sharing options...
jcub280 Posted April 7, 2012 Share Posted April 7, 2012 Same problem I am having on an old junker 83 turbo I just picked up. I am trying to find the culprit. Let us know if you find it. Quote Link to comment Share on other sites More sharing options...
jcub280 Posted April 7, 2012 Share Posted April 7, 2012 Sorry, I miss read your post. I was getting non-stop pulsing from the negative feed. I have that problem fixed now. Quote Link to comment Share on other sites More sharing options...
