ZAMMM Posted March 11, 2012 Share Posted March 11, 2012 I am thinking about getting a ebay champion radiator cause there affordable and look decent. Do I need a 3 row or will a 2 row cool fine. I have a l28et on a stand right now and plan on doing a efan conversion once I get the turbo motor in. I also live in FL and do not plan on having AC in the car when I do the swap. Just seeing if I need the 3 row or not from your experiance Quote Link to comment Share on other sites More sharing options...
aarang Posted March 11, 2012 Share Posted March 11, 2012 Just put a three row Champion in my ZXT. Works great so far with two Spal fans with a shroud. I would stick with the three row as the tubes in them are pretty small. The two row just has less of them. Quote Link to comment Share on other sites More sharing options...
Kash Posted March 13, 2012 Share Posted March 13, 2012 you can't over cool in Fl...go with the three row. Quote Link to comment Share on other sites More sharing options...
roger280zx Posted June 27, 2012 Share Posted June 27, 2012 Has anybody tried the 4 row. It looks hard to beat for the $$$. Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted June 27, 2012 Share Posted June 27, 2012 (edited) As far as I could tell all the cores were the same thickness. I got a 2 row because I thought it might be thinner and give more clearance for my electric fans, but it was the same as the 4 row copper radiator I pulled out. It cools great; I doubt the number of rows has much bearing on cooling ability, that is the amount of coolant and thickness/surface area of the core are the main factors. Edit: I am going to correct myself a little bit. The core thickness may in fact be thinner for the 2 row over the 3 row, it's the tank thickness that is the same. There may not be any reason at all to get a 2 row, unless you have restricted airflow, like a full size intercooler in front. Edited June 27, 2012 by SleeperZ Quote Link to comment Share on other sites More sharing options...
