Daphur280 Posted March 17, 2012 Share Posted March 17, 2012 Once upon a time I saw an aftermarket dead pedal that look similar, if not in fact actually, Momo pedal, much like the pedal kit MSA previously sold. However after an exhaustive search (5min on the internet) I came across no such pedal. And if anyone has big feet like me, you can share my frustration with the minuscule factory dead pedal. So I ventured out to a local pick n pull to see what factory dead pedals I might be able to swap over. Amongst my search I came across only 2 vehicles that had some-what suitable foot rests. The first came from a 3rd gen Jeep Cherokee underside: the second came from a 2000 Suzuki Grand Vitara underside: I was looking for something that would fit for both wide feet and long feet. Gonna look at the fitment tonight and post more! Quote Link to comment Share on other sites More sharing options...
Wedge Posted March 19, 2012 Share Posted March 19, 2012 Nice let us know how it works. Quote Link to comment Share on other sites More sharing options...
Pharaohabq Posted March 19, 2012 Share Posted March 19, 2012 WOW!, Let us know how it fits in there Big foot... I've been using the dead padal out of a 350Z. it's not so big, and I had to build a custon bracket but it works. Quote Link to comment Share on other sites More sharing options...
GOTHALOSISM Posted March 20, 2012 Share Posted March 20, 2012 If you cut off your left foot, then you will have no need for the pedal. Quote Link to comment Share on other sites More sharing options...
Daphur280 Posted March 20, 2012 Author Share Posted March 20, 2012 If you cut off your left foot, then you will have no need for the pedal. Yeah!! then I could get an automatic too!! 2 birds 1 stone. Quote Link to comment Share on other sites More sharing options...
Daphur280 Posted March 20, 2012 Author Share Posted March 20, 2012 (edited) So I had a chance to mock them up a bit tonight. granted the ECU was in the way, I think I got a general idea of what needed to be done. Here's a front shot of the long pedal, ignore the wiry mess: here's from a different angle: and another angle, you can see this one is pushed out a bit too far, I'm going to mess with a few shims to try different angles, and remove the ECU so I can get a proper fitment: The wide pedal took a bit of trimming, I had to cut the plastic tabbing and file down a cone off the bottom of it to rest against the factory pedal, which makes it perfect for mounting it to: You can notice this looks closer in similarity to the OEM pedals, Here's from another angle: and another angle, this one fits a little bit better and further away for a better angle when resting your foot, PLUS, the factory mounting lines up perfectly with the pedal, so drilling a hole to mount it may be easier than the long pedal: Personally I favor the longer pedal, but I will have to do a little more fab work to get proper fitment for both. Edited March 20, 2012 by Daphur280 Quote Link to comment Share on other sites More sharing options...
Six_Shooter Posted March 20, 2012 Share Posted March 20, 2012 Why not just attach a larger face/rest to the existing dead pedal? Quote Link to comment Share on other sites More sharing options...
Daphur280 Posted March 20, 2012 Author Share Posted March 20, 2012 Because I'm looking for a more "stock" look Quote Link to comment Share on other sites More sharing options...
Six_Shooter Posted March 21, 2012 Share Posted March 21, 2012 You could still have a stock look, by making a larger pedal face, that looks stock. Quote Link to comment Share on other sites More sharing options...
Daphur280 Posted March 21, 2012 Author Share Posted March 21, 2012 I dont have an injection mold or rubber compound mold to fabricate one, so this is the route I took. Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted March 21, 2012 Share Posted March 21, 2012 Looks great! Quote Link to comment Share on other sites More sharing options...
cygnusx1 Posted March 21, 2012 Share Posted March 21, 2012 (edited)  FWIW, you could attach a peice of 1/8" steel or 1/4" aluminum to the factory nub of a dead pedal, and then paint it black, and attach a Subaru dead pedal pad to the plate you made.  The subaru pads are flat plastic rectangles with ribs, and are held in place with two plastic rivets.  Easy to get too. Edited March 21, 2012 by cygnusx1 Quote Link to comment Share on other sites More sharing options...
Six_Shooter Posted March 22, 2012 Share Posted March 22, 2012  FWIW, you could attach a peice of 1/8" steel or 1/4" aluminum to the factory nub of a dead pedal, and then paint it black, and attach a Subaru dead pedal pad to the plate you made.  The subaru pads are flat plastic rectangles with ribs, and are held in place with two plastic rivets.  Easy to get too. Something like this is what I was thinking, though, I had something more like getting some generic rubber in mind, than looking for a specific car to pull something from. Quote Link to comment Share on other sites More sharing options...
