240sx tb modify to linkaged conversion
Which one did you end up getting by chance? I just got my hands on a 240sx throttle body and found out the brackets and springs cannot be transferred over from the 280zx (like the one from Graytech's diy) because the throttle plate rod was bigger than the 280zx. So I think I'm gonna have to convert to throttle cable instead.
I have the bottom cooled version with the larger shaft. Used those instructions. I tapped the shaft on the TB to the size I needed, used the 240sx spacer, and opened the hole on 280z linkage with a file. It wasn't too much different.
I also thought about filing down the linkage to fit, but I didn't think there was enough material to do so. You wouldn't happen to have pics of your setup would you?
