mikemac44 Posted March 29, 2012 Share Posted March 29, 2012 Hi,i would like to buy a package deal.Im after 1983? 1 280zx turbo ecu,complete engine wiring loom,airflow meter,turbo injectors,throttle body,distributor/crank angle sensor disc type,all for L28et conversion on 260z,cheers Quote Link to comment Share on other sites More sharing options...
billseph Posted March 29, 2012 Share Posted March 29, 2012 I've got several of the things you're interested in...everything but the ECU actually. I'll PM you. Quote Link to comment Share on other sites More sharing options...
borini63 Posted March 29, 2012 Share Posted March 29, 2012 (edited) I have: -280zx turbo ecu off 81 ZXT Auto $60 -Turbo air flow meter Remanufactured Python Brand $75 -turbo injectors a set of six $50 -T Body off 82 280ZXT $35 -distributor/crank angle sensor disc type $100 -Engine harness off 81 280ZXT $75 Also I ship over seas all the time! Thanks Jamal Edited March 29, 2012 by borini63 Quote Link to comment Share on other sites More sharing options...
tyler031734 Posted March 29, 2012 Share Posted March 29, 2012 Hi,i would like to buy a package deal.Im after 1983? 1 280zx turbo ecu,complete engine wiring loom,airflow meter,turbo injectors,throttle body,distributor/crank angle sensor disc type,all for L28et conversion on 260z,cheers Your also going to need the special dizzy shaft for that crank angle sensor type. I wouldn't get the throttle body. Waste of money for a 50mm. Just dont use a stock Jpipe. .02 Quote Link to comment Share on other sites More sharing options...
jyz77 Posted March 30, 2012 Share Posted March 30, 2012 (edited) I have a stock j pipe that already has a flare welded to fit a 60 mm throttle body. Ill take $35.00 Edited March 30, 2012 by jyz77 Quote Link to comment Share on other sites More sharing options...
mikemac44 Posted April 2, 2012 Author Share Posted April 2, 2012 Your also going to need the special dizzy shaft for that crank angle sensor type. I wouldn't get the throttle body. Waste of money for a 50mm. Just dont use a stock Jpipe. .02 Yep,got a new shaft,and found a larger throttle body since post,thanks mate Quote Link to comment Share on other sites More sharing options...
mikemac44 Posted April 2, 2012 Author Share Posted April 2, 2012 I have a stock j pipe that already has a flare welded to fit a 60 mm throttle body. Ill take $35.00 Thanks mate,ive already got that sorted. Quote Link to comment Share on other sites More sharing options...
