Critique my maxifuse install
so after scrolling through several of other people's setups, I noticed that no one wired their maxifuse block like I did, and I am starting to get a little concerned. Maybe someone can clue me in as to whether or not my wiring is not appropriate before I try to fire it up.
I have a scosche 4 fuse maxifuse block that has 3 inputs at the top for 2-4 gauge wires, and four out the bottom. I installed all the red-white wires appropriately to the bottom slots with appropriate fuses. For the three inputs at the top, I have one 4 gauge wire that goes to battery pos(+), one 4 gauge wire that coems from alternator output, and one 4 gauge wire that goes to the started solenoid (+).
So if wiring it this way is NOT okay, can someone please explain to me what I have done wrong and why it is wrong to wire it that way? Thanks All
What you have will work fine. You just connected everything the hard way.
The input block, has no current limiting, due to no fuse, obviously, and will transfer more current than the starter will ever pull.
The only concern is the slightly increased resistance through extra connections between the battery and the starter. This will also be affected over time, by exposure to the elements, causing corrosion and increased resistance over time.
I don't know why people want to use distro blocks that are meant for interior and audio installs under the hood.
true, until
Or the plating on the fuse box peels off and corrodes, or the terminal screws back out, or ....
Keep it simple. Wire it with 4 gauge directly from the battery to the starter.
I have all relays and the maxifuse block inside the cabin. Maybe 5 inches of cable from battery to maxfisue block, and the rest is in the diagram. The reason I did this was to keep from running two cables from the battery, but if this will be detrimental in the long run I will run the starter cable straight from the battery. I have a small deka etc14l battery moutned in the passenger floorboard. I suppose it really makes no nevermind whether I run the cable to the block or straight from starter to battery, other than it creates two connections straight to the battery pos(+)
Edited by emeraldlion
true, until
FWIW, I have use that style of connector under the hood, on battery terminals, for several years on daily driven (including winter) vehicles without any real issues. Only mentioned what I did because I have seen it happen to other peoples cars from time to time.
I try to avoid that style connection now, just to eliminate any possible problems before hand.
The plating flaking off will not cause an issue, at least not any more than the plating not flaking off, again, I've had the flaking happen on some of my terminals, with no additional problems compared to a fully intact plating. It just doesn't look as nice. lol
In this case, if the system is working, I wouldn't worry about it too much, especially if this terminal block is in the interior, like has been posted.
If I had to get in there and change something anyway, then I would take the time to make a direct connection between the battery and starter.
Speaking of small batteries, I should get my AGM battery set-up installed and working.
Yeah, but I don't have any radio a/c or interior lights other than in the dash. I am still a little leary, but thought I would give it a try. I will let you know how it goes. The CCA are 220, CA are around 360 if I remember correctly. I have also seen some test slips from the battery being tested showing 400+ CCA. It seems to have held up well for some people. Chevy 283 with about 9.2:1 cr.
  • 4 months later...
Just thought I would let you know but the way you have it wired will cause a fire if your alternator craps out ( this is from experience on a 77 280z )
the red and white wire that goes into the 80 amp fuse comes from the alternator + after it passes through this fuse (this fuse protects incase of over current from alternator) after going through this fuse it does 4 things... it supplies the other 3 fuses with power and it charges the battery. the red and white cables on the other 3 fuses supply power to things such as ignition, headlights etc. the last red and white wire comes straight from the alternator. if you have the original red and white and another 4 gauge wire connected to the battery you could have a fire hazard
  • 4 weeks later...
