Tuning help needed in true Nor Cal
spanishfly
post-4152-037101400 1334846495_thumb.jpgI am in need of a mechanic who knows way more than I do when it comes to fine tuning my 3.1 stroker. I live in the middle of nowhere so finding a knowledgeable zcar mechanic is easier said than done. I can bring the car to you and will pay good money to a GREAT mechanic who can tune my motor to it's full potential.I am halfway between Eureka and Yreka on the Klamath river, so if your a reasonable distance lets talk about specifics.
You might get a bit of help on here, if you let us know the details of your issue and whats in the Engine. Stock or Aftermarket Cam, Injector size, I see the airflow meter on it, Have you messed with that yet?. Spark plugs, and I see a Rising rate FPR.
I think that's just a plain old later model Z/ZX FPR for EFI. You can even see the mounting plate, edge-on, hanging on the side.
It is odd to have a stroker with a stock AFM on it though, considering the prevailing view that the stock AFM can barely handle a bigger cam. It looks like a stock engine except for the fuel rail. Who built it, where'd you get it?
Ld 28 crankshaft, l24 piston rods, arias 89mm(flat head with valve pocket),jdm timing set, N42 head 11/1 Compression,ported & polished,490/290 camshaft,arizona zcar performance oil pan. Engine built in Montebello,Ca.
I know that the stock fuel and ignition system are inadequate and i will upgrade when money allows.I have the timimg set to 15* BDTC and am running 110 octane race gas through 270cc turbo injectors. JSK fuel rail rising rate fuel regulator,60mm TB,cold air intake, and 3 to 2 to 1 header. I will have to look to see what plugs I bought from napa. I have not messed with AFM,I do not own any specialty tools like a vacuum gauge.It is much faster than stock, idle is rough with a lope, I do not want to hurt the engine due to ignorance and the lack of true mechanical training. I have only built and restored Datsun 1600 roadsters in the past. I would love to find a 280z wizard within 3 hours drive who has much more knowledge and tools than I. I found a dyno shop in San Jose(6 hour drive)but cannot get an appointment until May 17th.I am sufficient at brake jobs,clutch work, and basic automotive.post-4152-060563000 1334870303_thumb.jpg
Edited by spanishfly
You might try Classic MotorSports in Santa Rosa.
Ken Anderson has tuned my my Z in the past. He is very good with mikunis and fuel injection. Years ago I believe he did fuel injection tuning for Dave Rebello?
