Wasted spark/ edis
suparman
Look through here - http://forums.hybridz.org/index.php/forum/93-megasquirt/ for EDIS. Notice though, that you'll need an aftermarket EMS, like Megasquirt, to trigger it.
What might work better for you is a Pertronix unit, or a 280Z distributor with a separate GM HEI module, or a 280Zx distributor with a built-in E12-80 ignition module.
I'm setting up EDIS on my triple Weber'd Z using Megajolt. You need the EDIS stuff, a trigger wheel, sensor mount, controller and associated wiring. I'll break it down in my build thread once I'm done.
