Wideband O2 sensor toast?
madkaw
My AFR guage has been a little erratic lately. It seems to do okay at cruise, but during WOT and other times the guage drops full lean occasionally. I did some searching and it seems that coolant can contaminate the sensor and I did recently have a head gasket go which in turn put coolant in the exhaust. Anyone confirm this before I lay out the money for another sensor?
I will add the the guage worked great before this and I have checked all wires and pulled the O2 sensor out and recalibrated it according to the manual. I have also checked for loose grounds or wires.
I can confirm that water or coolant can most definitely kill widebands. A head gasket let go on the dyno once and the AFR on the wideband instantly showed 30:1 or higher, and wouldn't come back down on any other car afterwards.
You can try removing it and heating/cleaning it with a propane torch, but that has worked for me only for a short time, and not very often....
