'71 240Z washer motor replacement
Having just purchased my first 240Z and having just replaced the wiper motor with one from a '96 accord, appreciate this site when someone files a thorough "how to do it" complete with pics. I don't understand the relay part of the wiper to auto park.. but working on it.
Was searching forum for a washer replacement. I read one entry about a NAPA generic.. for $30 but no part# etc.
So for the fun of it, I asked the Parts Counter at Canadian Tire if they carried a washer motor for a '71 240Z .. after a snide chuckle.. wala.. he found a listing.
Here it is .. a TRICO 11-100 for $17.99 !!!! (made in USA)
Instructions talked about mounting to fender/firewall with attached bracket, but the round shape of it looked like it might fit the rubber holder on the jug.
So I bought it and here's the install since it worked perfectly.
Pump Model and size with jug in background:
You need to dremel off the attached plastic mounting plate:
Once cut off flush to circumference, it looks like this:
I used white grease to lube the cylinder & rubber holder to assist in insertion and then attached tube to inlet on pump:
Note outlet tube alignment (follows fender well profile) so you can hook it up to your washer hose:
Next I soldered new connectors that would mate with the original wiring harness [one male +, one female - ]:
Since the bain of these motors is rust, I covered exposed metal with film of white grease:
That's it.. re-install jug with wires hooked up and the outlet tube attached and test it out.....mine had great pressure/flow.
So far, the best $18 fix I've done.
Rrichterr
