LoneStarS30Z Posted May 29, 2012 Share Posted May 29, 2012 Yup, here's another one of those "which turbo?!" threads. I've just about dead set on running a GTX3076R or GTX3582R, either one with a .82 hot side. My question is, has any L guys touched these turbo's yet? From extensive Google searching, a lot of Evo guys, some RB guys, SRT4's folks and etc have run these with good look numbers. I know Big Phil ran something around 388HP - 415TQ IIRC on a regular GT35R. I'd like to reach those numbers too and I was wondering if the GTX30 would get close to that, or if the 35 would be overkill. I'm really just looking for personal experiences on L type engines, since the numbers coming from other engines is subjective. If you guys have any other suggestions feel free, I'm not entirely partial to Garrett's, but I am partial to quality ball bearing turbo's. Right now I have a cheapy 60-1 that needs a rebuild so I'm looking to spend big once on a good turbo. Thanks for any advice or input fellas. Quote Link to comment Share on other sites More sharing options...
Tony D Posted May 29, 2012 Share Posted May 29, 2012 Plain old GT35R is worth well more than that! JeffP made 475 on a stock Low-Compression bottom end using the GT35R...He's finding excuses now to refit the new "X" series because when we were doing the Forged Bottom End, the GT35R was running out of air above 17psi and 7,000rpms (600+ RWHP) He's just getting greedy! Who really needs an 800HP 7,800 rpm Street-Driver Turbo ZX? Quote Link to comment Share on other sites More sharing options...
PMC raceengines Posted May 29, 2012 Share Posted May 29, 2012 I love the 3076r on any motor between 2L and 3L so strong where you need it on the street The 3540 is a great race turbo and 450hp atw on the L28 pump fuel under 20psi , Quote Link to comment Share on other sites More sharing options...
Tony D Posted May 29, 2012 Share Posted May 29, 2012 Hey PMC---send me some in-country contact information via PM. I'm going to finish out here in the sea (New Caledonia) earlier than expected. It's a longshot, but maybe I can swing through. I'm up for pissing off the boss with wild flights to nowhere just for the hell of it! Quote Link to comment Share on other sites More sharing options...
letitsnow Posted May 29, 2012 Share Posted May 29, 2012 Take a look at the borg warner 7064 efr, it appears to be a pretty good fit for the L28. Quote Link to comment Share on other sites More sharing options...
LoneStarS30Z Posted May 29, 2012 Author Share Posted May 29, 2012 I've been reading the GTX3076 is damn near the same thing as the GT35R in terms of power and spool. I've been leaning towards that one, but I'd still like to see what others are using with their T3/T4 set ups. Quote Link to comment Share on other sites More sharing options...
zack_280 Posted May 29, 2012 Share Posted May 29, 2012 Well, I just blew a GT3582R and installed a new GTX3071R. If you look at the compressor and turbine maps the GTX3071R looks like a much better fit. I can't say too much from personal experience because I have barely driven the car with the new turbo and the old one had a warped shaft, but from the data I've gotten the GTX3071R with a 1.06AR turbine housing is spooling up a little later than the GT3582R with a .82AR turbine housing. From the seat of the pants feel the GT3582R felt faster, but I don't really have much hard data to do on and I am working through another unrelated issue that could be affecting the performance. I am using a different wastegate, but the upper manifold pressure is about the same at full boost. On another note, if you end up going the GT3582R route, I have the turbine housing with a wastegate that was installed when I bought the car. The housing was cut to install the wastegate (it is a Tial wastegate). I also have the down pipe. PM me if you are interested. I'm planning to post it up here in the for sale section today or tomorrow. Quote Link to comment Share on other sites More sharing options...
S30 SPL Posted May 31, 2012 Share Posted May 31, 2012 I don't have boost on my Z, but I do have the GTX3076R on my 2.5L Subaru. With 4 cylinders, I get 20psi of boost before 4k RPM and made a 373hp/386tq on a Mustang Dyno using 91CA pump gas. I imagine that it would work well with a L 6 cylinder engine. The turbo doesn't run out of breath up top, the stupid Subaru heads do. Quote Link to comment Share on other sites More sharing options...
LoneStarS30Z Posted May 31, 2012 Author Share Posted May 31, 2012 Decisions...decisions... Thanks for the input guys. zack_280, I'm assuming the downpipe is V-Band style, 3in? I might be interested in that if I can use it for whichever turbo I finally decide on. Quote Link to comment Share on other sites More sharing options...
zack_280 Posted June 1, 2012 Share Posted June 1, 2012 The down pipe is not V-Band and neither is the dump tube. I wasn't too happy with the down pipe because it brought the exhaust out too low. If someone buys the housing and dump tube, I would give them the down pipe, but I wasn't happy with it. My new housing is a V-band (so is the dump tube). I had a shop install a new wastegate on the exhaust manifold and fab up a new down pipe that tucks the exhaust under the trans tunnel very nicely. Now almost nothing scrapes under the car under normal driving conditions (like pulling out of my driveway). Quote Link to comment Share on other sites More sharing options...
roger280zx Posted June 2, 2012 Share Posted June 2, 2012 On 5/29/2012 at 12:14 PM, letitsnow said: Take a look at the borg warner 7064 efr, it appears to be a pretty good fit for the L28. Yup, the t3 7064 is the perfect bolt on for most any L28-L31 IMO. Those wheels are Bad A$$. Good luck finding one though, as every one seems to be out of stock. I hope they are available when I'm ready to upgrade. Quote Link to comment Share on other sites More sharing options...
LoneStarS30Z Posted June 2, 2012 Author Share Posted June 2, 2012 I'll look into that one too thanks for the idea. Quote Link to comment Share on other sites More sharing options...
240Z Turbo Posted June 8, 2012 Share Posted June 8, 2012 The GTX3576r is likely a better choice as opposed to the GTX3076r. Better match of the turbine wheel to the engine and compressor wheel. Please reference my results between these turbochargers. GTX3076r vs GTX3576r Quote Link to comment Share on other sites More sharing options...
