Rrichterr Posted May 30, 2012 Share Posted May 30, 2012 (edited) Well, the nightmare happend to me .. you pull the release and it just keeps coming out. It's at this time that you wished you'd paid more attention to the exact details of how that release works or had a nearby 240Z that you could orient yourself to before proceeding .. but I had neither. So checking the forums yielded a couple of methods.. from below or unbolt front hinges... but lacked detail as to exactly what one was to do... other than fishing around with a screwdriver.. So after tackling this from below with strategic lighting and those extendable mirrors, I finally understood what had to be done (besides applying bandages to my scraped arms thanks to those pipe clamp botls) If a detailed write-up had been available, it would have been a snap ... so here's my contribution for the yet to experience this joy of reverse hood openings Here's the plan of attack: 1) jack front up and place on stands (block rear wheels) .. you need room to crawl around under the middle of the Z 2) get a smaller pry bar ... about 10" long will do; shorter and you can't reach it (unless you have longer arms than mine) ; longer, you can't get any leverage to free it as the handle will hit the pipe/other. 3) you need to crawl under the vehicle and you are going to be using your right arm to access the area adjacent to the exhaust pipes ... so make sure you have allowed the Z to cool down before proceeding. Looking up past the pipes and toward the firewall, you should be able to see the hood release bracket assembly using a trouble light or a small LED... it has an access hole in the bottom of it. . here's a closer view.. 4) you need to insert the pry bar into the hole in the bottom of the hood latch bracket with the bent tip in the pry bar facing toward the drivers side 5) here's the release arm end (that shiny nut in the center of the bottom access hole) that you are trying to pry toward the drivers side. note.. mine has already been modified with a bolt inserted.. suspect original one is just the square black metal with a slot to hold the cable end. 6) placing the pry behind (toward the passenger side of the car) the release arm and using the edge of the bottom access hole as a leverage point, push the handle of the pry bar toward the passenger side, thus moving the release toward the drivers side... and it should pop the hood. 7) here's what the removed latch looks like on mine.. (note the sqaure opening is oriented toward the passenger side.) Having successfully opened the hood, and without a replacement cable to feed back thru the cable sheath, I found a similar cable assembly off of a snowblower (the one they use for clutch/drive or for auger engage) and modified it to be installed along side the original as a temporary workaround until I can secure an original cable. Hope this helps you if this ever happens to you. Pics too large... have modified to 1024x768..thx, Edited May 30, 2012 by Rrichterr Please Resize Images to: 1024 x 768 pixels or close, before placing on HZ. Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted May 30, 2012 Share Posted May 30, 2012 It's way more difficult with a V8 pushed back to the firewall....ask me how I know. Quote Link to comment Share on other sites More sharing options...
Mike Mileski Posted June 7, 2012 Share Posted June 7, 2012 In addition to the hood latch cable, I attached a second cable and routed it down the left side of the firewall so it can be easily grabbed and pulled by reaching up from under the driver's side of the car, just in case. Mike Mileski Tucson, AZ Quote Link to comment Share on other sites More sharing options...
Tony D Posted June 13, 2012 Share Posted June 13, 2012 I'm with Mike---after the release broke on my 73, I double-hooked another cable (used one of those PTO Engagement Cables for a small tractor---overkill to the max, but suggested to me by an oldtimer who has one as an emergency backup to his shaved door handles on his 70 240Z AND on his 51 Mercury (yeah, he's been hotroddin' a while...) The PTO cable is plenty long to place it up behind the bumper which is a nice place to hide it. Shorter Choke-Style Cables can go there, or in the wheel well for emergency release. And frankly, I've found myself using the 'emergency release' more regularly because I don't have to open the door! Quote Link to comment Share on other sites More sharing options...
