R200 or R180?
PR280z
I`ve read some where here on raising the car and spinning the tire for a certain count,but i cant find the post. i think it was M2 that made the post??? while we`er here on this topic...i can`t get loose the diff drain plug or the filler plug on my diff. is there a way of getting them loose???
It's just a ratio. If you don't have uneven drag on your wheels, you can mark both wheels and the pinion flange, then turn the drive shaft until both wheels turn one complete revolution. Count the number of turns of the flange to get the ratio. You'll have to guesstimate the .336, .54, .7 or .9 at the end. 1/3, 1/2, 3/4, almost all the way. If the wheels turn unevenly, you can lock one wheel, turn the flange until the other wheel does one revolution and divide the flange turns by 2.
Use a torch on the metal around the plugs. Apply heat. It makes a big difference.
No link in your last post.
