redbull z Posted June 27, 2012 Share Posted June 27, 2012 I bought the headliner and trim replacement kit from MSA and there are no instructions as to taking the trim pieces or the headliner out. The trim pieces seem to be tucked under the weather stripping and the head liner is under the trim pieces. if anuone could help me by telling me how to remove these pieces it would be greatly appreciated. Link to comment Share on other sites More sharing options...
MidnightRider Posted July 2, 2012 Share Posted July 2, 2012 You'd probably have better luck under interior Link to comment Share on other sites More sharing options...
drdiabetezx66x Posted December 10, 2014 Share Posted December 10, 2014 (edited) I bought the headliner and trim replacement kit from MSA and there are no instructions as to taking the trim pieces or the headliner out. The trim pieces seem to be tucked under the weather stripping and the head liner is under the trim pieces. if anuone could help me by telling me how to remove these pieces it would be greatly appreciated. I just removed some of the vinyl trim from above the doors and above the windshield so I could get the rubber molded pieces that keep it secured to the top sides. I did this so I can install the pieces in a different car. You have to get the weather stripping off then you can get under the trim pieces. Then go to the end of that piece of trim and there is s rubber "u" shaped piece of rubber that keeps the vinyl pinched to the the car. If you find the end u can simply carefully start pulling it and it will pull the vinyl trim away from the car. Same for all 3 pieces along the top that surround the headliner. Hope that helps. I can take pictures Sunday if not. Edited December 10, 2014 by drdiabetezx66x Link to comment Share on other sites More sharing options...
drdiabetezx66x Posted December 10, 2014 Share Posted December 10, 2014 Also bought s new headliner material and did it myself. Link to comment Share on other sites More sharing options...
