coilover questions...
well, im still new to the classic z scene. i was wondering. im looking into putting coilovers on mine (79 280zx) and eveything ive found says you need to weld something here and there and cut and grind and all this stuff that is kinda out of my league. does no one make an actual bolt on coilover kit? im coming out of the s-chassis scene and im pretty much jumping into this project head first. any help would be great. thanks
There is no such thing as bolt on coilovers. That car uses strut cartridges for the front that that you just plop into a tube. That tube also has the spindle for the wheel hub and bolts directly to the control arm.
In this pic, the middle is a stock strut tube with no cartridge, notice how it also has the spring seat, the far right is a full unit directly pulled from my car, the left is when I chopped most of the tube off and test fit an s13 coilover over the tube for welding.
Then I chopped off this crap from the lower coilover sleeve. mounting bracket and brake line
This is the finished product after welding on the sleeve and powdercoating.
