RebekahsZ Posted August 19, 2012 Share Posted August 19, 2012 My 240z firewall flexes a good bit when im boogieing thru the gears at the drag strip. Anybody got a picture of some sort of bracing from the clutch master to the inner fender or something similar? Quote Link to comment Share on other sites More sharing options...
Miles Posted August 20, 2012 Share Posted August 20, 2012 You must have a hefty clutch. What MC and slave are you using? Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted August 20, 2012 Author Share Posted August 20, 2012 Clutch and slave are stock LS2/2006 GTO. Master is 1" tilton. It is stiff, but not THAT stiff. My foot likes it. But, when bleeding the clutch, my wife says that when I first break the bleeder fitting loose, the clutch actually pushes up against her foot before going down. Send photos of your support brace if you got 'em. I gotta fix this variable-pedal clutch behavior. Can't go to track with this going on. If it turns out that I need a new master, I"ll be reducing to diameter to 7/8". Somehow, my car knows when I'm racing. Around town, even if I shift fast, I have no problem. Go racing, car fairly consistently won't go into 3rd or 4th. Boogied through the gears hard on my street and came to a roaring stop at the stop sign, then I couldn't get car into gear until I came off the clutch pedal and rested the car for about a minute. Then it drove fine. The variable in this equation that I can identify is my vigor. I would consider drivetrain movement, but car has poly motor mounts and it doesn't move much. Possessed Z-car! Quote Link to comment Share on other sites More sharing options...
letitsnow Posted August 24, 2012 Share Posted August 24, 2012 Why not brace the end of the MC to the strut tower or similar? Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted August 24, 2012 Author Share Posted August 24, 2012 Thats the new plan. I'll post pictures when done. Waiting for rod-ends from Speedway. Switching from a series Tilton 75 MC to a series 74 MC tonight so that there is something to attach the brace to. Quote Link to comment Share on other sites More sharing options...
letitsnow Posted August 25, 2012 Share Posted August 25, 2012 Check this thread out, it's about RX7's, but applicable to you too. http://www.norotors.com/index.php?topic=10256.0 Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted August 27, 2012 Author Share Posted August 27, 2012 That's the basic idea, except with my master cyl, the hydraulic line comes out of the snout of the master cyl. I have my parts together and the new master cylinder installed. If I get done with work early enough, I'll have car at fabricator tomorrow. Final product to be posted late this week. I had hope that with a smaller master cyl the firewall wouldn't sag so much, but it still does. I think bracing up the firewall will give me a fair amount of more useable pedal. Quote Link to comment Share on other sites More sharing options...
Fuzzydicerule Posted August 27, 2012 Share Posted August 27, 2012 Do you have a strut tower brace? it would be fairly easy (as far as my overstimulated, under rested, insomniac brain is concerned at 1:45 AM) to tie in a bar from the STB straight back to the clutch and brake MC mounts (ive watched how much the firewall flexes under brake pressure, it needs it too... Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted August 27, 2012 Author Share Posted August 27, 2012 No, I haven't reinstalled a STB since doing the V8 swap. Good idea. Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted August 29, 2012 Author Share Posted August 29, 2012 Back from fabricator. Clutch feels SO much better! Quote Link to comment Share on other sites More sharing options...
johnc Posted August 29, 2012 Share Posted August 29, 2012 You do know that you're putting the load through an aluminum casting that's not designed to take a load like that. Keep an eye on the MC. Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted August 29, 2012 Author Share Posted August 29, 2012 Yes, I agree. Will keep an eye on it as your suggest. Sometimes the simple solution is the right one, but sometimes it backfires. Interestingly, while my pedal feels much more confident and firm, I still have clutch disengagement trouble. Going inside the bellhousing - I've tried to avoid it, but it is inescapable. Quote Link to comment Share on other sites More sharing options...
