shri2222 Posted August 23, 2012 Share Posted August 23, 2012 (edited) I ordered a Cometic Head gasket for a N/A looking at how all the passages matched the block, Now that I have received it, I noticed one port is block. Will this be ok?, or am I in for trouble if I use it? And is that a oil passages or coolant? I also posted some comparison HGs Edited August 23, 2012 by shri2222 Quote Link to comment Share on other sites More sharing options...
z-ya Posted August 23, 2012 Share Posted August 23, 2012 (edited) Cometic is now making L28 head gaskets? Awesome! Last I spoke with them they we not planning on doing the tooling to produce these. Founds this: http://www.shopengineparts.com/parts.aspx?eid=965&cid=24&type=engine&vtype=Import&make=Nissan&model=L-Series+Inline+6 You can probably have someone punch a hole there that has a punch press. If it is coolant, you are probably OK as it looks like there is another coolant hole just opposite the blocked one. Edited August 23, 2012 by z-ya Quote Link to comment Share on other sites More sharing options...
shri2222 Posted August 23, 2012 Author Share Posted August 23, 2012 Cometic is now making L28 head gaskets? Awesome! Last I spoke with them they we not planning on doing the tooling to produce these. Founds this: http://www.shopengineparts.com/parts.aspx?eid=965&cid=24&type=engine&vtype=Import&make=Nissan&model=L-Series+Inline+6 You can probably have someone punch a hole there that has a punch press. If it is coolant, you are probably OK as it looks like there is another coolant hole just opposite the blocked one. Yea, they make them now, I just got mine in yesterday from topend performance, They make them per order, the box it ships in has the cometic part number and the production date on the label. It looks great to, I ordered their 0.060 1.5mm only thing is that one passage. Quote Link to comment Share on other sites More sharing options...
shri2222 Posted August 28, 2012 Author Share Posted August 28, 2012 Can anyone please either link or post a oil feed/return and coolant feed/return labeling or diagram of a f54 and P90 head? Thanks ahead Quote Link to comment Share on other sites More sharing options...
NewZed Posted August 28, 2012 Share Posted August 28, 2012 www.xenons130.com/reference It's in the lc chapter. Lubrication and Cooling. Quote Link to comment Share on other sites More sharing options...
PMC raceengines Posted August 28, 2012 Share Posted August 28, 2012 there both water ways the oil is on the other side. Quote Link to comment Share on other sites More sharing options...
nash542001 Posted September 20, 2012 Share Posted September 20, 2012 there both water ways the oil is on the other side. Did anybody find an answer if this will affect cooling of the head? I am asking Racetep if this will be an issue? I will reply with their answer when I find out. Quote Link to comment Share on other sites More sharing options...
steve260z Posted September 21, 2012 Share Posted September 21, 2012 Here's my thread on the same/similar issue. I've not quite completed the motor install so I can't provide any feedback on the gasket yet. Mine's a stroker but still applies. Steve http://forums.hybridz.org/index.php/topic/98875-90mm-gasket-coolant-holes/page__p__927430__fromsearch__1#entry927430 Quote Link to comment Share on other sites More sharing options...
