_X_ Posted October 10, 2012 Share Posted October 10, 2012 Hey Has anyone ever used the stock exhaust manifolds from any ls engine in a z?? Quote Link to comment Share on other sites More sharing options...
akeboshi Posted October 10, 2012 Share Posted October 10, 2012 (edited) If they look anything like the VH41 manifolds (what I heard anyways) they should fit great. If you want to be sure ask member fuzzydicerule.He just finished an ls1 swap and for some reason he made his own so maybe not. Edited October 10, 2012 by akeboshi Quote Link to comment Share on other sites More sharing options...
SUNNY Z Posted October 10, 2012 Share Posted October 10, 2012 With the JCI kit, there are limited options that work I believe. Build your own mounts, and a newer c6 or gxp mani might work. Quote Link to comment Share on other sites More sharing options...
Kevin.pk Posted October 10, 2012 Share Posted October 10, 2012 (edited) I used stock 98-99 Z28 manifolds. I had to cut off the flanges and weld an extension on to the end but they work. I built my own mounts but my engine placement is very close to where the JCI kit puts the engine. edit: listed the wrong years Edited October 12, 2012 by 280zcar Quote Link to comment Share on other sites More sharing options...
wfritts911 Posted October 11, 2012 Share Posted October 11, 2012 280zcar, I think those are 98-99 F-body manifolds, the newer ones were cast iron instead of the stainless steel. Cant really weld to the cast iron unless your a welding wizard. I do believe those F-body manifolds would fit though, thats what I was trying to find until I purchased some 98-99? vette manifolds. I will say the vette manifolds will not clear the stearing shaft on the drivers side even if you make them into serios block huggers. They do however, fit really well through the 280z hood vents -Will Quote Link to comment Share on other sites More sharing options...
Kevin.pk Posted October 12, 2012 Share Posted October 12, 2012 You're right. I had a brain fart. 98-99 manifolds Quote Link to comment Share on other sites More sharing options...
mattd428 Posted October 19, 2012 Share Posted October 19, 2012 I welded my own mounts and used 2007 c6 manifolds. Quote Link to comment Share on other sites More sharing options...
