Charging problems
akumazedex
So here's where I'm at, I have an 82 s130. Every time I turn the lights on the voltage drops super low, to battery voltage, and stays there at idle. Car starts to run rough. I have a new alternator in there with clean battery connections. When I turn the lights off it smoothes out. I'm running hid's so I don't see why they would pull that much current. This is a recent problem.
I'm super stumped right now, any help would be great.
  • 3 weeks later...
  • 11 months later...
I would like to share my experience with something similar I went thru recently on my 83.....I even changed alternator and still no charging and I have hid but with a full harness with relay and feeding straight from the battery....the no charging problem was found by a buddy of mine when no one else could figure it out.. on the same side where the battery is on the zx (passenger side) theres a black relay box right in front of the strut tower and theres a relay that protects the charging system...change it and it should take care of youre problem...
