stony Posted November 8, 2012 Share Posted November 8, 2012 The one that AEM supplies is not working for my setup. Looking for one that is MAP based with 1000cc injectors. Quote Link to comment Share on other sites More sharing options...
ZT-R Posted November 8, 2012 Share Posted November 8, 2012 (edited) What brand injectors? Still using your resistor box? what is your map sensor? 3.5 bar aem, 5 bar aem, gm 3 bar, ect? edit, also post your current tune. Edited November 8, 2012 by ZT-R Quote Link to comment Share on other sites More sharing options...
stony Posted November 8, 2012 Author Share Posted November 8, 2012 What brand injectors? Still using your resistor box? what is your map sensor? 3.5 bar aem, 5 bar aem, gm 3 bar, ect? edit, also post your current tune. My current tune is the one that is in the AEMtuner. i have not modified it i was going to try to take away fuel today and see what happens. HKS1000cc lo imp inject 5.0 bar aem map no resistor box Quote Link to comment Share on other sites More sharing options...
ZT-R Posted November 8, 2012 Share Posted November 8, 2012 Do you have the battery offsets for those injectors? Quote Link to comment Share on other sites More sharing options...
ZT-R Posted November 8, 2012 Share Posted November 8, 2012 All mine are 3.5 bar Quote Link to comment Share on other sites More sharing options...
stony Posted November 8, 2012 Author Share Posted November 8, 2012 Do you have the battery offsets for those injectors? OK never heard of that??? im assuming since the rb tune that came from AEM all that kind of stuff is setup already??? NO?? Quote Link to comment Share on other sites More sharing options...
stony Posted November 8, 2012 Author Share Posted November 8, 2012 OK never heard of that??? im assuming since the rb tune that came from AEM all that kind of stuff is setup already??? NO?? My last experience with a EMS was SDSEFI ;> That was really easy ;> Quote Link to comment Share on other sites More sharing options...
ZT-R Posted November 8, 2012 Share Posted November 8, 2012 (edited) Battery offsets are different for every injector manufacturer. let me see if i can find em. Yo do know that the basemap on the aem one is TPS based fuel right? I wouldnt use that with a big TB setup. I think they used that because of the stock butterflys. Edited November 8, 2012 by ZT-R Quote Link to comment Share on other sites More sharing options...
ZT-R Posted November 9, 2012 Share Posted November 9, 2012 (edited) pm me your email address. it willnt let up upload the cal. Attached is an older one of mine usings the following setup OEM rb26 440cc injectors on a peak hold driver.... You will need to change this according to your injector needs. i am thinking you have HKS Fuel Injectors (1402-RA002) Injector Top Feed Includes Injector Harness Connector Color : Light Blue Flow Rate : 1000cc Style : Low Impedance In which case i would find the specs on them to see the resistance and all but you might could use a percision or RC or something low impedence to get it on the trailer. AEM 3.5 map sensor. Being that you using a 5 bar this will totally change the tune. you can interpolate if you like and you can probably get her running enough to get it on the trailer. A little trick you can use is to copy the igntion map and the fuel map to a picture file and then go to the setup wizard and change to a 5 bar. then pull up your pictures and kinda figure out what the values need to be. (it changes the Y axis). probably go though the setup wizard and select all your engine specific stuff. Edited November 9, 2012 by ZT-R Quote Link to comment Share on other sites More sharing options...
stony Posted November 9, 2012 Author Share Posted November 9, 2012 Battery offsets are different for every injector manufacturer. let me see if i can find em. Yo do know that the basemap on the aem one is TPS based fuel right? I wouldnt use that with a big TB setup. I think they used that because of the stock butterflys. Yea i changed it to MAP Quote Link to comment Share on other sites More sharing options...
stony Posted November 9, 2012 Author Share Posted November 9, 2012 nothing attached? Quote Link to comment Share on other sites More sharing options...
stony Posted November 9, 2012 Author Share Posted November 9, 2012 nevermind i got it. Quote Link to comment Share on other sites More sharing options...
stony Posted November 17, 2012 Author Share Posted November 17, 2012 ZTR I didn't post before BUT the HKS 1000cc injectors were in the injector wizard !!!! ;> Quote Link to comment Share on other sites More sharing options...
ZT-R Posted November 17, 2012 Share Posted November 17, 2012 Yea i saw that the other day, I was supprised. Quote Link to comment Share on other sites More sharing options...
