BloodOnTheApex Posted December 4, 2012 Share Posted December 4, 2012 It seems that I have enough parts laying around, Datsun and not, to have gone ahead and started to have crazy ideas for a new project.I have an L24 bottom end, seems to be from 1971. It's been rebuilt at some point in the past, bored 1 mm over. I would like to bore and stroke it. Perhaps I would not go larger than 2.8, since I doubt I can afford a diesel crank. I'm not sure if a bore past 86 mm is safe or worth the expense of custom pistons. I would like to remain in the realm of factory parts as much as possible.I suppose that L28 NA dished pistons would be best, bringing the compression somewhere around 8.3:1. I would like to use the E31 head I have available, but with larger valves and some port work. This head would raise the compression a bit, yes? I would like to be closer to 8.5:1. I suppose I could use a P90 head and flat tops, but I would like to use what is most commonly available and what I already have.The fun part: I have a pair of Zenith Stromberg carbs that I picked up from a friend in Norway. They were factory modified by Volvo for blow through turbo use. One carburetor fed a 1.9 litre single cam 4 banger with a Garret T3 turbo. They bolt directly to the L6 SU manifold. I would like to run both carbs with a 60 Trim T3 whatever intercooler I can find to fit. I'm not sure at this point if these carbs would provide too much fuel for a 2.8, and if the needles would have to be changed. If they have to be changed, that would be a real bummer, since they're specific to these carbs and were never available in the US.Utilizing L28ET, L24, L28E parts, I believe this engine could be built almost completely with OEM parts.What to y'all think? How quickly would I explode this junk yard collage?Any thoughts or experience with methanol/water injection would be apperiated. Quote Link to comment Share on other sites More sharing options...
madkaw Posted December 5, 2012 Share Posted December 5, 2012 I would run what ever is the cheapest and easiest. Why spend a bunch of money boring and stroking a motor you might just blow up anyway. Quote Link to comment Share on other sites More sharing options...
BloodOnTheApex Posted December 5, 2012 Author Share Posted December 5, 2012 I already have most of that stuff. There's a couple NA 280zx's at my local yard. I figure I can just bore this block another 2 mm and slap in 280z internals. I would like to increase diplacement for 2 reasons: 1) To take full advantage of the amount of fuel these carbs will flow. A single carb may be used on a 2.3 litre 4 cylinder at 10 psi. 2) To avoid fabricating an intake manifold. I was hoping an adequate intercooler, timing, and perhaps meth injection would help to prevent detonating this engine to pieces. I only plan to run 10-12 psi.....Okay, maybe 15. 15 would be nice. Quote Link to comment Share on other sites More sharing options...
madkaw Posted December 5, 2012 Share Posted December 5, 2012 So you want to bore the p30 block to put in l28 internals? I guess I'm missing something here. Just grab one of those zx motors and work it. It sounds like those carbs are too much for any L displacement anyway. Quote Link to comment Share on other sites More sharing options...
Tony D Posted December 7, 2012 Share Posted December 7, 2012 Nothing like making more work for yourself on something you plan on breaking anyway. Less talk, do it and tell the results. Wanking endlessly on what if scenarios and overly-complex mechanisms for power when adding boost does the same thing with a flick of your wrist. I can show you non-stroked 1100hp L28ET's Can you show me a 3.2 in that power range? Verified? Put it together first. Then turn up the boost. The L20ET ran to 680HP, you plan on needing more than that? Quote Link to comment Share on other sites More sharing options...
