EvilC Posted April 30, 2013 Share Posted April 30, 2013 Firewall def isn't cut on Austin's car. Looking at this http://sites.google.com/a/vq240z.com/www/frontsubframe - the engine needs to sit lower for sure and double check the crossmember, looks like more material needs to be removed. Quote Link to comment Share on other sites More sharing options...
zero Posted April 30, 2013 Author Share Posted April 30, 2013 (edited) Yeah It definitely needs to go lower. Looking at my crossmember in an earlier post, I cut pretty much exactly the same amount of material out as Austin. looking at where his throttle body sits relative to the cowl, I need to go about an inch down and half an inch back. We'll see if there is enough wiggle in the mounts to get it down. And for the record, I wasn't talking about cutting the firewall, but the bracing on the inside of the hood. Edited April 30, 2013 by zero Quote Link to comment Share on other sites More sharing options...
Pharaohabq Posted April 30, 2013 Share Posted April 30, 2013 (edited) I don't believe Austin cut into the firewall https://sites.google.com/a/vq240z.com/www/enginemounts Ahh You're right, Austin didn't cut into the firewall. Still it's a tight fit, and w/o cutting in, you'll probably have to mod that crossmember some more. I guess I was confusing Austin and Myron's build. I know Myron really cut into the firewall. I guess Austin's only cut was for that sensor on the lower right. Anyway it's how you can make it fit. If you lower it a little more you might have more room. The engine looks like it's tilted up a little in front. Why brace the hood? It's not supporting anything but itself. Rather than the "traditional" hood clips to hold it shut, I'd like to see someone Get a second stock latch and move them to the corners, connected by a cable. You then pull the Stock handle inside and it unlatches both corners. Edited April 30, 2013 by Pharaohabq Quote Link to comment Share on other sites More sharing options...
astroboy Posted April 30, 2013 Share Posted April 30, 2013 So just to be clear, is there anything below the engine/transmission that is restricting the engine to be mounted lower in bay/tunnel? Quote Link to comment Share on other sites More sharing options...
zero Posted April 30, 2013 Author Share Posted April 30, 2013 No, just the engine mounts on the cradle, the mounts and cradle are slotted, so I think if I slide the isolaters up I might be able to drop the engine a bit. We'll see Quote Link to comment Share on other sites More sharing options...
Pharaohabq Posted April 30, 2013 Share Posted April 30, 2013 Not that I know of, In this case it looks like the only things that could prevent it from being mounted lower is the Steering crossmember, or his engine mount crossmember. The only other thing which I would certainly hope would never be an issue is the pavement below Quote Link to comment Share on other sites More sharing options...
zero Posted May 1, 2013 Author Share Posted May 1, 2013 (edited) Fiddled with it a bit yesterday. For the engine about .5" lower and further back. Still just barely hits the hood but its not bad now. What's keeping it from going lower is the engine cradle/mounts/isolaters, nothing is hitting. I'm either gonna trim the hood or look into slightly shorter isolaters or both. Here are some pics of how it sits now. Edited May 1, 2013 by zero Quote Link to comment Share on other sites More sharing options...
Pharaohabq Posted May 13, 2013 Share Posted May 13, 2013 Can you see where's it's hitting? You may need to cut the mounts off the side L brackets and re position another .5 inch or so. that should give you the space w/o too much other modification. How is the steering crossmember looking now? Also, is the tranny bolted up, or is it still hanging too? if it is, jack the tail up a little and see if the hood clears. it's tight... Quote Link to comment Share on other sites More sharing options...
zero Posted May 14, 2013 Author Share Posted May 14, 2013 After entirely too much fiddling, it turns out the trans had to move down a little bit. I ended up making some spacers to drop the tail of the tranny, and therefore the throttle body, a bit. Also made some inner plates for the trans mount. Going up to test it today. Quote Link to comment Share on other sites More sharing options...
Pharaohabq Posted May 24, 2013 Share Posted May 24, 2013 Nice, I guess that works too. The engine is still pretty level right? You shouldn't have any issue with oil pooling toward the rear of the engine.. Quote Link to comment Share on other sites More sharing options...
zero Posted June 13, 2013 Author Share Posted June 13, 2013 So It's been a little while since I've updated this, but I've got a little progress to post. The mounts are welded in, at least as much as I can get to without pulling the engine back out. It will certainly be enough to start it and get it running well before I paint the engine bay. I also followed Austin's lead and cut the ends off of the stock headers and welded some bends on there to clear the firewall so I can start the thing without burning up the car. I'll be tying into an existing LS exhaust at some point. Quote Link to comment Share on other sites More sharing options...
