Stainless V-bands to mild steel/aluminized tubing?
RebekahsZ
If I plan to get the exhaust ceramic coated after it is built, is there any problem with welding 304 stainless V-band flanges to mild steel or aluminized exhaust tubing?  I want the V-bands to be easy to assemble/dissassemble for many years to come, but I don't know anything about welding and metalurgy to know if there will be a problem with that welding interface with the dissimilar metals.  I'm hopeful that regular gas-mig welding like exhaust shops use will be OK.  Recommendations/suggestions?
 You can do just that. The weld will rust though. Unless it is coated also. I have done it a number of times. It's not ideal but it if you want to tie into an existing mild steel exhaust system like I did it will hold up just fine.I used E70s wire in my MIG. I have also TIG welded mild steel to 304 stainless with er308 rod. It works. Again its not ideal. Some turbo manifolds use mild steel flanges with stainless runners with good results. I wouldn't worry about it if you had it done. Just my .02
Edited by ozzzzz
The weld will be brittle, and will eventually crack and break under the vibration and heat an exhaust system sees. Personally, I'd get the right flanges in mild steel. I've seen stainless headers welded to mild steel flanges with standard ER70S2 MIG wire not even last a year, but most last two years or sometimes more on street cars before they break.
You would better off using 309L filler for welding mild steel to stainless.  It will reduce (but not eliminate) the potential for cracking and will reduce future corrosion in the weld itself.  Being in Alabama, the exhaust will most likely rust from the inside out (due to condensation) so an external coating won't help a lot with that.
I just did this very thing... Figure the exhaust only has to last a year and said "Screw it" and welded it up.  For a serious street car you only want to do this once on, I'd recommend doing what John recommended.  You may also want to consider sending the pieces out to be coated.
Mike
I really appreciate the amount of input.  The reason I went with stainless flanges was so that they would stay easy to disconnect for years to come (I take stuff apart often).  If the welds crack-they'll be very easy to disconnect!   I'll check my local welding supply store for the 309L filler.  I haven't ordered my tubing yet, but I'll consider trying to get 304 stainless instead of mild steel.  I was planning to use LOTS of bends because my frame notches for exhaust cutouts are at an awkward angle and I'm a psycho for ground clearance, but as usual I'm probably being a little neurotic and going overboard. I kind of hate how even stainless discolors, so I was going to send it all off to JetHot for coating inside and out, guess I could still do that with stainless, but then I'm really being psycho!
Edited by RebekahsZ
Thanks-will do!  JetHot 2000 it is!  Is 2000 good enough, or should I go for an even higher temp coating (worth the money)?  Sorry, gonna stick with something that looks pretty.
You guys have helped a lot.  I'm gonna order some mild steel flanges for the headers themselves (exhaust pipe tubing is cheap, but I sure don't want to have trouble with my header cracking).  I'll use the stainless flanges on my tail pipe sections.
Next question:  if I use a mild steel flange on the header, and a stainless flange on the first section of exhaust pipe with a shared v-band clamp, do you think it will have sealing problems due to dissimilar expansion properties?
