WTB l28et distributor/harness connector (82-83 cas)
SDgoods
I don't know what your project is - if you are repairing the stock harness or installing megasquirt or something. When I installed megasquirt, I found that the connector that was supplied with the car was prettty mangled. I just used 4 regular female insulated crimp on spade connectors. They fit inside the dist housing fine. The only issue is you have to keep track of which one goes where.
Sam
Edited by Sam280Z
Im switching to the 82 83 optical crank angle sensor. My car had the distributor but for whatever reason the po used the external sensor. So all i neee is that portion of the harness. Ill try your idea and hack the harmess end off the external sensors wire
  • 1 month later...
