Oil Pump Shaft Clocked
Ben's Z
Turn your engine to timing marks for ignition on cylinder one specs, mount the distributor and see where the rotor is in relation to the cylinder one lead? Thats what i would do anyway
What are you worried about? As far as i know it is not critical timing on this axel, it runs the oilpump and the distributor. The oilpump doesnt care about timing and the distributor is very much adjustable. Slap it together adjust the ignition and be on you merry way :)
