destro79 Posted February 15, 2013 Share Posted February 15, 2013 ok i have been trying to find anythreads for the ignition timing but have not been able to find any threads at the moment any help would be good, planning to use the megasquirt wiring, and looking at possibly a crankshaft sensor, have 81 turbo distributor, thank you for help any other advise would bee appriciated, building motor with wiring outside of vehicle then installing. Quote Link to comment Share on other sites More sharing options...
loy Posted February 15, 2013 Share Posted February 15, 2013 (edited) One person grounded every 2 out of 3 teeth, added a hall effect sensor and made it a 30-1. http://forums.hybridz.org/topic/77233-30-1-tooth-wheel-with-cherry-hall-effect-sensor/ Another section in here http://forums.hybridz.org/topic/23244-megasquirtnspark-mssmsns-installation-guide/ talks about removing the wheel and re-drilling the alignment hole and rotate the wheel by one whole so you know it's about 72 degrees. Edited February 15, 2013 by loy Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted February 15, 2013 Share Posted February 15, 2013 I'm not sure what you're asking about timing. Are you asking how to get an rpm signal to megasquirt? Quote Link to comment Share on other sites More sharing options...
Tony D Posted February 15, 2013 Share Posted February 15, 2013 (edited) All requested information is in the Megasquirt EMS Sub-Forum at this site. Edited February 15, 2013 by Tony D Quote Link to comment Share on other sites More sharing options...
destro79 Posted February 16, 2013 Author Share Posted February 16, 2013 ok i have a stock n/a 79 280zx would it be easier to install the 79 distributor for my turbo build or get the 81 crank angle sensor and install it or even get the 82-82 dizzy, i will be using the megasquirt wiring. Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted February 16, 2013 Share Posted February 16, 2013 Depends if you want ms to control ignition timing. If so one of the turbo dizzys will be easier to set up. With the na dizzy you would need to lock the advance mechanisms. Quote Link to comment Share on other sites More sharing options...
destro79 Posted February 16, 2013 Author Share Posted February 16, 2013 ok that makes it easier cause i would like to control it by computer (ms) is their a link on how to lock the advance mechanisms on the n/a dizzy (for temporary use) Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted February 16, 2013 Share Posted February 16, 2013 One guy said he used jb weld. I have a small mig welder so that's what I used. Quote Link to comment Share on other sites More sharing options...
destro79 Posted February 16, 2013 Author Share Posted February 16, 2013 the problem for me isn't what to use to lock the mechanism but what exact part and how to access. Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted February 16, 2013 Share Posted February 16, 2013 I don't know of a link but you will have to completely disassemble the distributor. Once you're in there you should see how the mechanism works and figure a way to lock it. Maybe the fsm shows this? Quote Link to comment Share on other sites More sharing options...
destro79 Posted February 16, 2013 Author Share Posted February 16, 2013 from what i recall it doesn't show how to disassemble the distributor but ill look when i get home Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted February 16, 2013 Share Posted February 16, 2013 You should only need a roll pin punch and a phillips screw driver if memory serves. Quote Link to comment Share on other sites More sharing options...
destro79 Posted February 16, 2013 Author Share Posted February 16, 2013 ok, i have been searching the forums for any thing that could help out before i get ahead of myself, no luck yet and also using google. Quote Link to comment Share on other sites More sharing options...
destro79 Posted February 16, 2013 Author Share Posted February 16, 2013 (edited) you think its possible to use the advance with the mega squirt system without locking the dizzy and have it work fine? just came to mind and hows this for disassemble and recondition? http://atlanticz.ca/zclub/techtips/distributorrebuild/index.html Edited February 16, 2013 by destro79 Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted February 16, 2013 Share Posted February 16, 2013 That exploded view should help...and no, the dizzy needs to be locked. Quote Link to comment Share on other sites More sharing options...
destro79 Posted February 16, 2013 Author Share Posted February 16, 2013 ok ty and on the dizzy shaft for the 82-83 turbo would i have to take the front timing cover off to change the gear thats on the crankshaft or is it like plug and play? Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted February 16, 2013 Share Posted February 16, 2013 I'm not real sure I've never had to pull one. Is it damaged? Quote Link to comment Share on other sites More sharing options...
destro79 Posted February 16, 2013 Author Share Posted February 16, 2013 im just trying to find out what would be easier to do, install my 81 turbo dizzy and get a crank pulley and sensor for it, or cut my loss and by the 82-83 turbo dizzy and shaft, unless the 81 turbo shaft would work? Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted February 16, 2013 Share Posted February 16, 2013 I'm thinking you may have to pull the front cover. I'm not sure if the oil thrower will come past the seal. Quote Link to comment Share on other sites More sharing options...
destro79 Posted February 16, 2013 Author Share Posted February 16, 2013 oil thrower? haven't heard of that part in my search yet. Quote Link to comment Share on other sites More sharing options...
