Jwinnsrt Posted March 20, 2013 Share Posted March 20, 2013 My 77 280z manuel trans will shift into all gears when car is off but when car is on and in neutral won't go into any of the gears Quote Link to comment Share on other sites More sharing options...
motomanmike Posted March 20, 2013 Share Posted March 20, 2013 Was this something that happened over night, or a gradual issue? Did you just purchase the car? Did the car sit for an extended period of time? Sounds like when you are pressing the clutch pedal it isn't disengaging the clutch enough. Slave cylinder, or master cylinder issues could be the culprit, could be a cracked clutch fork there are many possibilities. Its possible the clutch is toast but we need some more information than it just won't go into gear. Quote Link to comment Share on other sites More sharing options...
Jwinnsrt Posted March 20, 2013 Author Share Posted March 20, 2013 I resently purchased the car about a week ago it was driving great and shifting smooth I drove the car eariler yesterday everything was fine that night I went for a late night cruise as I was leaving my house as I was trying to shift into the gears it felt really notchy and hard to get into gears until I came to a complete stop in neutral with clutch all the way down to the floor wouldn't go into any gears. So I had to turn the car off shift into 1st gear and start car in gear to make it back home Quote Link to comment Share on other sites More sharing options...
rags Posted March 20, 2013 Share Posted March 20, 2013 Is the clutch master cylinder reservoir filled? If so, when you depress the clutch pedal does the slave cylinder move the clutch fork? Quote Link to comment Share on other sites More sharing options...
Jwinnsrt Posted March 20, 2013 Author Share Posted March 20, 2013 I checked the clutch master cylinder reservoir and It was very low. I added fluid but it still won't shift into gear while car is on:( Quote Link to comment Share on other sites More sharing options...
rags Posted March 20, 2013 Share Posted March 20, 2013 very low as in empty? Did you look at the slave cylinder to see if it or the rubber hose leading to it is leaking? Quote Link to comment Share on other sites More sharing options...
Jwinnsrt Posted March 20, 2013 Author Share Posted March 20, 2013 It wasnt empty fluid level was just kind of low I will check to see if the slave cylinder of ruber hose is leaking as soon as I return home Quote Link to comment Share on other sites More sharing options...
Jwinnsrt Posted March 20, 2013 Author Share Posted March 20, 2013 I just checked my slave cylinder every time I touch the black ruber part on it it squirts out fluid a leaks so I believe this may be the problem. It looks simple to replace just remove the 2 bolts holding it on. Is there a way to bleed the line without having the tool? Quote Link to comment Share on other sites More sharing options...
EuroDat Posted March 20, 2013 Share Posted March 20, 2013 Tool? You can bleed the clutch hydraulics at the bleeder on the slave cylinder and someone in the car to push down the clutch peddle. You need a small 8mm ring spanner for the bleeder. If it full of fluid its probably worn out. Tip: Loosen the hydraulic hose before removing the slave cylinder. That way you can screw the slave cylinder off by hand. Quote Link to comment Share on other sites More sharing options...
Jwinnsrt Posted March 22, 2013 Author Share Posted March 22, 2013 thanks alot guys. The problem was the bad slave cylinder which was leaking i replace it and bleed the system car shifts great!! Quote Link to comment Share on other sites More sharing options...
