redzedturbo Posted March 22, 2013 Share Posted March 22, 2013 Okay me and xnke built a turbo ( t04e 50 trim turbonetics/ stock .63 a/r turbine bored to fit .76 t31 wheel with a 3/8'' spacer welded to the manifold with studs) anyway the intake was removed as with all the wiring and when i hooked it all back up my temp gauge in the dash no longer works! What would cause this i have checked the wiring at the thermostat housing what gives? everything in the car works but this...... Quote Link to comment Share on other sites More sharing options...
big-phil Posted March 22, 2013 Share Posted March 22, 2013 Try a continuity test from the plug at the thermostat to the plug on the gauge there could possibly be a break in the wire after removing the intake manifold. I've also had this happen on my 78 but it always seems to be at the thermostat I will wiggle it unplug it and plug it back in and eventually it will start working again Quote Link to comment Share on other sites More sharing options...
djwarner Posted March 22, 2013 Share Posted March 22, 2013 The oil pressure gauge and temperature gauge share the same power supply. If your oil pressure gauge is working, the problem is almost certainly at the sensor or the wiring to the gauge. Quote Link to comment Share on other sites More sharing options...
redzedturbo Posted March 22, 2013 Author Share Posted March 22, 2013 Thanks for the reply guys will do and hopefully it will work im tired of charging my laptop to see my temp thru megasquirt. Quote Link to comment Share on other sites More sharing options...
FricFrac Posted March 27, 2013 Share Posted March 27, 2013 The temp gauge for MS (and the stock ECU) should be the CHTS which is different than the sensor on the thermostat housing for the temp gauge... Quote Link to comment Share on other sites More sharing options...
