subtle_driver Posted April 2, 2013 Share Posted April 2, 2013 I tried to search for a flange, so I can make my own downpipe for my l28et swap into my 240z, on google and here, but no luck. The flange I need is the four bolt to downpipe. Quote Link to comment Share on other sites More sharing options...
Gollum Posted April 2, 2013 Share Posted April 2, 2013 http://www.racepartsolutions.com/products.asp?cat=102 Quote Link to comment Share on other sites More sharing options...
subtle_driver Posted April 2, 2013 Author Share Posted April 2, 2013 I dont see the exit flange on there. Unless im blind. Quote Link to comment Share on other sites More sharing options...
Gollum Posted April 2, 2013 Share Posted April 2, 2013 should be one of these http://www.racepartsolutions.com/proddetail.asp?prod=JOD-96500D Quote Link to comment Share on other sites More sharing options...
subtle_driver Posted April 2, 2013 Author Share Posted April 2, 2013 (edited) The flange on thel28et stock turbo wg housing is rectangle pattern, the ones on the link you sent look square. Here is a pic of the stock outlet for reference: http://i521.photobucket.com/albums/w332/uthawki/Brown%20car/104_2059.jpg Edited April 2, 2013 by subtle_driver Quote Link to comment Share on other sites More sharing options...
jtpaintballwdp Posted April 3, 2013 Share Posted April 3, 2013 Should be one of those 4 bolt flanges. I can go meausre my bolt spacing if you need it. Quote Link to comment Share on other sites More sharing options...
subtle_driver Posted April 3, 2013 Author Share Posted April 3, 2013 Did you happen to order one from them before? Quote Link to comment Share on other sites More sharing options...
subtle_driver Posted April 3, 2013 Author Share Posted April 3, 2013 It would be great help if you could verify the correct part for me to order :-/ Quote Link to comment Share on other sites More sharing options...
Gollum Posted April 3, 2013 Share Posted April 3, 2013 Or you get the 5 bolt flange and make your own wide mouth downpipe that allows for better wastegate flow... I'm pretty sure the 4 bolt is a standard t3 piece. A lot of the pics on the net are a 3" hole pictured though which I think skews the perception. It WOULD be nice to get some 100% confirmation though, and that I can't give you. I can just try to point you in the right direction. Quote Link to comment Share on other sites More sharing options...
Gollum Posted April 3, 2013 Share Posted April 3, 2013 Nevermind, that 5 bolt is certainly NOT the right one for the stock T3 Quote Link to comment Share on other sites More sharing options...
