Sotenacious Posted April 21, 2013 Share Posted April 21, 2013 Hello hybrid z I have a question regarding the triple weber carb kit that is for L series engines. Well i am planning on getting the carb kit but i'm not sure which one to get. Here is a video of my car specs on the engine are in the description. Not sure what cam but here is what i think it is Grind: 17036. Lift(In/Ex): .495/.495. Duration(In/Ex): 290/290 any thoughts on this. Quote Link to comment Share on other sites More sharing options...
Sotenacious Posted April 21, 2013 Author Share Posted April 21, 2013 Also as you know from the video the exhaust sounds very raspy, even now with a resonator the raspy sound is gone but I want a sound like this but without paying an arm and a leg. Quote Link to comment Share on other sites More sharing options...
duragg Posted April 21, 2013 Share Posted April 21, 2013 Make your life easier and go see Dave: http://www.rebelloracing.com/ Quote Link to comment Share on other sites More sharing options...
duragg Posted April 21, 2013 Share Posted April 21, 2013 Is that Briann510s old car? Quote Link to comment Share on other sites More sharing options...
Sotenacious Posted April 21, 2013 Author Share Posted April 21, 2013 Is that Briann510s old car? Don't think so i got it off of some mexican guy that didn't assemble the engine correctly so all of the valves hit the pistons. So i found a head that had lots of work done to it, that's why i don't know what cam is in it. Quote Link to comment Share on other sites More sharing options...
BluDestiny Posted April 21, 2013 Share Posted April 21, 2013 (edited) I don't think you have that aggressive of a cam. it idles too smoothly. I had a stage 4 cam kit from MSA (the one with the specs you described) and it idled like a muscle car. I had triple weber 40's and a 6-1 header with a 3" exhaust to some no name super turbo muffler. http://s995.photobucket.com/user/Richard316/media/My%20260Z/PICT0034.mp4.html If you want to keep it fairly streetable you should get the 40's. Edited April 21, 2013 by BluDestiny Quote Link to comment Share on other sites More sharing options...
Sotenacious Posted April 21, 2013 Author Share Posted April 21, 2013 I don't think you have that aggressive of a cam. it idles too smoothly. I had a stage 4 cam kit from MSA (the one with the specs you described) and it idled like a muscle car. I had triple weber 40's and a 6-1 header with a 3" exhaust to some no name super turbo muffler. http://s995.photobucket.com/user/Richard316/media/My%20260Z/PICT0034.mp4.html If you want to keep it fairly streetable you should get the 40's. Well its going to be a weekend car. Not really going on the track. I know im going to have to port match with the 45's what is the difference in terms of how the perform? Quote Link to comment Share on other sites More sharing options...
Sotenacious Posted April 21, 2013 Author Share Posted April 21, 2013 anyone else? Quote Link to comment Share on other sites More sharing options...
T-Bone028 Posted April 21, 2013 Share Posted April 21, 2013 I have a 3.1L with a similar grind cam and I'm currently going through the process of rebuilding and installing 40 DCOE's. I currently have SU's with SM needles. I run out of steam around 5500 RPM. My car doesnt do any track time, and is a weekend driver...that being said, I'm more interested in street-ability with revs staying under 6500-7000 RPM. DCOE's are almost infinitely adjustable, and for a mild street motor, I'm thinking 40's will be fine, just need to play with chokes and jets if I run out of breathing room at higher RPM. But for me, I'm more interested in balance and fun throughout the entire rev range...so for MY application, the 40's will hopefully be enough until I save up enough disposable income for ITB's. Quote Link to comment Share on other sites More sharing options...
duragg Posted April 21, 2013 Share Posted April 21, 2013 I just pulled my 40s and installed 45s as I am track only now. Will make a smokin deal on my 40s for someone with DCOE experience. Quote Link to comment Share on other sites More sharing options...
steve260z Posted April 21, 2013 Share Posted April 21, 2013 I might be interested in the Carbs. What price are we talking? Thanks steve Quote Link to comment Share on other sites More sharing options...
Sotenacious Posted April 22, 2013 Author Share Posted April 22, 2013 I just pulled my 40s and installed 45s as I am track only now. Will make a smokin deal on my 40s for someone with DCOE experience. Does it have the manifold and linkage and how much? Quote Link to comment Share on other sites More sharing options...
duragg Posted April 22, 2013 Share Posted April 22, 2013 Carbs only. Linkage and other stuff is still on car. $400 for all 3? A new owner would need to rejet them, although I have a setup for a mild Z I can give you. 45f9 / 115 or 120 mains / 30 and 34 chokes. They also have an extra Progression hole CNC milled. DCOE Carbs are not plug and play.. they will change your life forever so don't expect greatness without a big investment in time and search-function. I had them running pretty darn good and dyno'd up to 7000+ RPM I don't mean to jack your thread. I apologize for putting this here. Quote Link to comment Share on other sites More sharing options...
T-Bone028 Posted April 22, 2013 Share Posted April 22, 2013 Duragg, PM sent Quote Link to comment Share on other sites More sharing options...
ram75280z Posted April 23, 2013 Share Posted April 23, 2013 The carbs, and how they're set up, need to be matched to the cam primarily. Naturally there's tuning involved for other modifications though. There used to be a little dos program floating around the web that Dave Andrews did up (around 1997 i believe) for the 510 crew that gives the information you need to properly setup a set of DCOEs based on engine size & peak power rpm. I have it saved at home. Anyway, if you want, & have a cam that can provide peak power much above 6000rpm=270+ duration, you're better off with the 45s. The 40s flow capability really levels off above a 34mm choke. It doesn't really matter what cam you have, or carbs really, if you use a 32mm choke, your peak power will occur below 6000rpm. If that's where you want the power to peak at, then you might as well use a stock induction setup, with a stage 1 cam, as that's what they're built to do. Quote Link to comment Share on other sites More sharing options...
