Dillon Posted June 12, 2013 Share Posted June 12, 2013 As the title states, Im looking for either a stock 280zx rear disk set up OR a modern-motorsports bracket/kit. Just let me know what you have. Thanks! Quote Link to comment Share on other sites More sharing options...
yem73z Posted June 12, 2013 Share Posted June 12, 2013 I have the full TechnoToyTuning r 230 swap with the rear disc conversion available. Quote Link to comment Share on other sites More sharing options...
Dillon Posted June 12, 2013 Author Share Posted June 12, 2013 I have the full TechnoToyTuning r 230 swap with the rear disc conversion available. I just seen that lol, i already have everything i want for the rear of my car im just looking to put disk brakes on it and be done with the rear; plus i cant spend that much money, but i apreciate it! Quote Link to comment Share on other sites More sharing options...
borini63 Posted June 13, 2013 Share Posted June 13, 2013 I have a rear calipers and rotors from 83 280ZX Turbo if you're still looking. $120 shipped Quote Link to comment Share on other sites More sharing options...
Dillon Posted June 15, 2013 Author Share Posted June 15, 2013 I have a rear calipers and rotors from 83 280ZX Turbo if you're still looking. $120 shipped Do you have the bracket to mount the calipers also? thanks Quote Link to comment Share on other sites More sharing options...
borini63 Posted June 15, 2013 Share Posted June 15, 2013 Do you have the bracket to mount the calipers also? thanks The brackets are welded to the control A arms! Quote Link to comment Share on other sites More sharing options...
LanceVance Posted June 15, 2013 Share Posted June 15, 2013 The brackets are welded to the control A arms! The first post's wording leaves something to be desired, but I believe the OP is looking for a rear disc conversion for an S30 that uses S130 components. That or a MM 240sx setup... Quote Link to comment Share on other sites More sharing options...
Dillon Posted June 15, 2013 Author Share Posted June 15, 2013 Yes, I thought that some 280zx's came with bolt on brackets, while some others were welded on. Confusion on my part. Basically like lance stated, I'm looking for a mm 240sx kit or a kit that uses 280zx parts. Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted June 26, 2013 Share Posted June 26, 2013 I am going to get a whole different kit for my whole braking system this fall. If you can wait, my Maxima rear brakes will be available then as well as some spare calipers and brake lines. Sending my smallest wheels to Arizona Z Car for a test fit on Friday to see if I can use their kit. Quote Link to comment Share on other sites More sharing options...
