mistah mofro Posted June 30, 2013 Author Share Posted June 30, 2013 On 6/30/2013 at 2:07 AM, NewZed said: Looks like you have coolant leaking in to the crankcase. A leak can happen at the front cover from what I understand. Doesn't have to be the headgasket. You're going to destroy the wear surfaces in the engine that depend on oil if you keep driving it with coolant mixed with your oil. Bearings, pistons, valve guides, etc. havent driven on its just been sitting for the time being Quote Link to comment Share on other sites More sharing options...
Domzs Posted June 30, 2013 Share Posted June 30, 2013 (edited) Are you loosing any coolant ? Edited June 30, 2013 by Domzs Quote Link to comment Share on other sites More sharing options...
NewZed Posted June 30, 2013 Share Posted June 30, 2013 (edited) Still needs an oil change. Leon was right. Forgot to say that I don't think that any fluid - oil, oil/coolant blend or whatever - should be propelled out of the PCV tube hole if the level is correct. Otherwise the PCV system would suck the crankcase dry as oil got thrown up there. You probably have a crankcase full of foam. Edited June 30, 2013 by NewZed Quote Link to comment Share on other sites More sharing options...
mistah mofro Posted July 7, 2013 Author Share Posted July 7, 2013 Found out the problem. My dizzy took a poo poo and I replaced it with a new e12-80 and now chirpin tires In 2nd. thanks guys for all the insight and I just swapped my motor out for an l28 so I can tear down the l24 and maybe save another chassis. Quote Link to comment Share on other sites More sharing options...
