PLATA Posted June 29, 2013 Share Posted June 29, 2013 I reconnected the steam tube line back to the coolant system , but want a cleaner look , any tips on clamps options are welcome >>> Quote Link to comment Share on other sites More sharing options...
cockerstar Posted June 29, 2013 Share Posted June 29, 2013 I've always liked using beverage clamps (used on CO2 systems for fountain soda), as they look a little cleaner. I'm sure there's another name for them, but that's how I discovered them. The only down side is that they aren't easy to remove and a pain to install without the right tool. http://www.ebay.com/itm/10-15-7mm-BEVERAGE-CLAMPS-STAINLESS-HOSE-CLAMP-/330602935606 ABA clamps made by Norma are also a little cleaner than traditional clamps. They have a beveled edge so they don't cut into the hose, and the serrations don't go all the way through the band. They're still the same basic look though. http://www.ebay.com/itm/SILICONE-HOSE-CLAMP-8-16MM-NORMA-TORRO-GEMI-TYPE-10PK-/150502895380 Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted June 29, 2013 Share Posted June 29, 2013 Relocate your tee fitting to underneath the coil cover? BTW- I never considered venting the steam vents to the heater lines-good thinking! Did you tee into the heater supply line or the return line? Quote Link to comment Share on other sites More sharing options...
cockerstar Posted June 29, 2013 Share Posted June 29, 2013 Relocate your tee fitting to underneath the coil cover? BTW- I never considered venting the steam vents to the heater lines-good thinking! Did you tee into the heater supply line or the return line? Easy = good Put them under the coil covers and be done with it! Quote Link to comment Share on other sites More sharing options...
SUNNY Z Posted June 29, 2013 Share Posted June 29, 2013 Just index the clamps to where the worm gear is on the back side. Helps a lot. Might have to flip them though Quote Link to comment Share on other sites More sharing options...
PLATA Posted June 29, 2013 Author Share Posted June 29, 2013 Relocate your tee fitting to underneath the coil cover? BTW- I never considered venting the steam vents to the heater lines-good thinking! Did you tee into the heater supply line or the return line? ^^^ That area is tight and the room is occupied by the heater two hoses plus cutting the cover . Yes the vent tube is purged to the return on the w/pump. Quote Link to comment Share on other sites More sharing options...
LanceVance Posted June 29, 2013 Share Posted June 29, 2013 Look up Gates 'PowerGrip' clamps; I haven't used them personally, but I plan on using them once I get to that point in my build. Very clean, and you can use some nice nylon sheathing over the hoses to really make things look good! Quote Link to comment Share on other sites More sharing options...
PLATA Posted June 30, 2013 Author Share Posted June 30, 2013 (edited) ^^^^ This is the look >>>>>>>>>> in the hunt. LanceVance thanks for the tip Edited June 30, 2013 by PLATA Quote Link to comment Share on other sites More sharing options...
T-Bone028 Posted June 30, 2013 Share Posted June 30, 2013 There's a cheap option from Spectre called "Magna-Clamps" that you can find from Summit/Jegs/etc. Basically worm-gear type clamp with a flashy cover to make it look like an AN fitting. I've seen some for $6-$10/pair dependent on size. Here's a link for 1-inch diameter. http://www.summitracing.com/parts/spe-3268 Quote Link to comment Share on other sites More sharing options...
socorob Posted June 30, 2013 Share Posted June 30, 2013 There's also heat shrink clamps. Only problem is if one happens to fail on the road you can't change it out easily. Quote Link to comment Share on other sites More sharing options...
TimZ Posted June 30, 2013 Share Posted June 30, 2013 (edited) There's also heat shrink clamps. Only problem is if one happens to fail on the road you can't change it out easily. http://www.mcmaster.com/#heat-shrink-hose-clamps/=nf1zrr Not very serviceable, but in some cases that's not that big a deal. The main question becomes whether you think you'll need to take that joint apart for any foreseeable service, or can you just treat the whole thing as one assembly during service. Edited June 30, 2013 by TimZ Quote Link to comment Share on other sites More sharing options...
shupee Posted June 30, 2013 Share Posted June 30, 2013 I use the gates heat shrink.clamps looks very neat IMO Quote Link to comment Share on other sites More sharing options...
PLATA Posted June 30, 2013 Author Share Posted June 30, 2013 ^^^^ good tips guys , thanks and keep sending suggestions Quote Link to comment Share on other sites More sharing options...
PLATA Posted June 30, 2013 Author Share Posted June 30, 2013 A car nut at the AM Sunday Coffee/Gas meet came up with easy fix >> barbecue paint Quote Link to comment Share on other sites More sharing options...
