Fuel Injectors
Well got my 500cc injectors with fuel lines, new connectors etc.
Now waiting on my tuned ECU. I have an 88 ECU that is being altered to run a Z32 MAF tuned for my setup. 8.5 to 1 compression, Schneider's 270-60F-14 cam.
Once this is done I have a personal friend that inherited his brothers tuning shop and I get free dyno sessions. Will see what numbers I can make with this setup. Hoping to get 250 hp with 10 to 12lbs of boost on the stock T3. Not a tall order I think.  If the numbers look good and all sounds good I will try a 15lb pull just to see what it has.
So, I plan on starting at 7lbs, then 10lbs, then 12lbs and then 15lbs. As long as setting the controller nets those numbers.
