Zmanj87 Posted July 26, 2013 Share Posted July 26, 2013 Need to bleed the brakes looked everywhere for the bleeding rotation start and end Quote Link to comment Share on other sites More sharing options...
Nigel Posted July 26, 2013 Share Posted July 26, 2013 Driver's side rear then passenger side rear. Passenger side front then driver's side front. Is this not in the service manual? Nigel Quote Link to comment Share on other sites More sharing options...
Zmanj87 Posted July 26, 2013 Author Share Posted July 26, 2013 It might be but. Went through it twice and just tells you how to bleed not where to start and end thanks Nigel! Quote Link to comment Share on other sites More sharing options...
Nigel Posted July 26, 2013 Share Posted July 26, 2013 No problem. Maybe it was the Haynes manual I read it in. They tend to provide more basic info. Regardless, the rule of thumb is to start farthest from the master cylinder. Strangely enough, that turns out to be the driver's side rear if you look at the actual line lengths. Nigel Quote Link to comment Share on other sites More sharing options...
NewZed Posted July 26, 2013 Share Posted July 26, 2013 It's in there but it just says "Bleed air as follows; Rear wheels --> Front wheels" . Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted July 26, 2013 Share Posted July 26, 2013 Doesn't matter. Front and back are separate reservoirs and totally separate systems. I recently bled mine. I did the drivers rear first and when I got to the passenger rear there was like one tiny bubble in it. Quote Link to comment Share on other sites More sharing options...
m1ghtymaxXx Posted July 26, 2013 Share Posted July 26, 2013 Rule of thumb is to go from furthest to closest to the M/C, since the lines run along side the passenger side, the sequence is as mentioned above. Quote Link to comment Share on other sites More sharing options...
