Daphur280 Posted July 27, 2013 Share Posted July 27, 2013 Similarly to this post: http://forums.hybridz.org/topic/113455-internal-wastegate-t3t4-woes/ I am running into a similar issue. My lever arm was at a funky angle, so I attempted to "clock" the turbo to get the appropriate angle, in addition the inlet was pointing straight out into the inner fender, so I needed to clock the angle to install the piping. Once it was clocked where I needed it the lever arm is out of reach from the flapper assembly. Its at the correct angle from the flapper, so that its 90 deg. but its about 1" off. So can I adjust the lever arm (unscrew) so that it reaches or leave it be and figure something else out? Also, should I be concerned about the housing touching the manifold? Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted July 27, 2013 Share Posted July 27, 2013 Yes you can lengthen the rod. You can try to find a thicker gasket to move the compressor off the manifold. Quote Link to comment Share on other sites More sharing options...
Daphur280 Posted July 27, 2013 Author Share Posted July 27, 2013 Yes you can lengthen the rod. You can try to find a thicker gasket to move the compressor off the manifold. Thanks I'll give that a try Quote Link to comment Share on other sites More sharing options...
mattb3562 Posted July 28, 2013 Share Posted July 28, 2013 There is also plenty of wall thickness in the manifold to remove 3/16". While in the process, I would also wrap it and blanket the turbo. You will be glad you did while you're at it instead of later. Quote Link to comment Share on other sites More sharing options...
mattb3562 Posted July 28, 2013 Share Posted July 28, 2013 Also, when you adjust your actuator rod, you're supposed to preload the waste gate. Screw it out to where it slips over the swing arm, and then back it up 2 rounds to where you have to slightly pull the actuator arm over the swingarm on the waste gate. This takes all the slack out of the operation. Quote Link to comment Share on other sites More sharing options...
CarJway Posted August 1, 2013 Share Posted August 1, 2013 (edited) I welded two 3/8" or 1/2" T3 flanges on my manifold to get the clearance I needed. Edited August 1, 2013 by CarJway Quote Link to comment Share on other sites More sharing options...
softopz Posted August 17, 2013 Share Posted August 17, 2013 Spacer for clearance. And bend the bracket a bit Quote Link to comment Share on other sites More sharing options...
