The Woj Posted July 28, 2013 Share Posted July 28, 2013 Does anyone know what this is? It is a small box mounted to the back of the speedo. The red wire goes into the speedo next to the high beam indicator light, and I don't know where the yellow wires went as I pig tailed them a long time ago. The outside of the box says "132", inside the clear top I can read "XP-34". The FSM refers to it as a "Switch Element", I am not sure what the heck that means. Thanks! Quote Link to comment Share on other sites More sharing options...
tooquick260 Posted July 28, 2013 Share Posted July 28, 2013 The white 2 wire plug looks like the one that goes to the interior light dimmer. my guess Quote Link to comment Share on other sites More sharing options...
NewZed Posted July 28, 2013 Share Posted July 28, 2013 Could be the BCDD 10 mph switch. Quote Link to comment Share on other sites More sharing options...
The Woj Posted July 28, 2013 Author Share Posted July 28, 2013 Forgot to mention this is on a 73 240Z. Quote Link to comment Share on other sites More sharing options...
The Woj Posted July 28, 2013 Author Share Posted July 28, 2013 Could be the BCDD 10 mph switch. I think we have a winner, wasn't sure how this would be the answer on a carb'ed car but this post seems to confirm NewZed's answer. http://forums.hybridz.org/topic/77476-speedometer-question/ I guess it was just a thing for the Hitachi carb'ed cars, as it seems the 70-72's didn't have this box and the 280z's had a similar box with different wiring. Quote Link to comment Share on other sites More sharing options...
Professor Threadkiller Posted August 3, 2013 Share Posted August 3, 2013 (edited) Does anyone know what this is? It is a small box mounted to the back of the speedo. It's a speed detecting switch that disables the throttle opener system below 13mph. And yes, it's like the carb version of the BCDD. (Or the BCDD is like the FI version of the throttle opener system?) The throttle opener holds the throttle open a little under high intake manifold situations and that switch disables that system when you are sitting still (<13mph) so you're idle won't hang open. That's why when you goose it sitting still the idle won't hang, but if you push in the clutch and goose the throttle while you are cruising at 30mph, the throttle should hang open a little bit. See ET-13 for additional details. On edit - The earlier cars had the throttle opener system, but didn't have the speed related defeat. Edited August 3, 2013 by Professor Threadkiller Quote Link to comment Share on other sites More sharing options...
