280zx leak problem could use some help.
HenneR
i have my 82 280zx and i have a persistent leak in my car i am trying to fix any help or suggestions would be great as my mechianical knowledge is limited but, i am trying to learn more. it seems to be at the transmission my guess is the rear main seal.
Well you know its either coming from the rear main seal or the front seal in the tranny. So take the tranny off, install a new clutch and resurface your flywheel and change the rear main seal. Then do the front seal on the tranny. Then you shouldn't need to open it for another 50k miles.
BD makes a good point.  If you're going to fix it no matter what, it's probably one of those two , and they both require transmission removal.  So you might as well drop the transmission.  But if you're going to live with it for a while, it's good to know which, since the transmission has no dipstick.
