FS5W71B - Item that might be overlooked on rebuild often?
inline6
The installed seal is backwards.
Rule of thumb is to install the seal so that increasing the pressure on the seal will make it seal tighter...as you've got it installed, the seal will be pushed away from the shaft as the pressure against the seal increases.
Flip the seal and it will be correct.
Oh!  Totally makes sense that the seal will be pushed away from the shaft as any pressure pushes on it.  Wow.  Learned something today.
  • 9 months later...
Another thing that happens when you install a seal backwards.
If you look close at a factory seal there are very small angled wipers (raised ribs) where it rubs on the sealing surface. Angled sort of like the blades of a fan. Paying attention to the rotation direction these wipers should be wiping oil back into the trans. If the seal is backwards they will wipe oil towards the out direction. Not all seals have these wiper ribs, especially aftermarket.
Also if you have the wrong seal for the application the seal may appear to fit but the wipers can be pointed in the wrong direction.
On the clearance of the rear bushing. It might be tighter once it's installed.
Edited by Chris Duncan
